Export Closed Polyline Area total to Excel by Layer
Message 1 of 11
I am new to the forum and have only basic knowledge of lisp routines and have been trying to search for and or create a lisp routine to export the area of multiple closed polylines by layer.  I would like the lisp routine to export a .csv file with the first column having the name of the file, without .DWG, the second column would contain the area of each individual closed polyline, the third column would contain the layer name.  Ideally the file would be sorted/grouped by layer type and then have a total area for each  layer type.  I am not even sure if this last request is possible.
Below is my attempt by using a routine I found and trying to edit it.  I am unsure how to create the routine to group by layer and get the sum of each layer to display correctly.  Thanks a ton for any help or insight you can give.
(defun c:EPD2 (/ ss i area layer all_data pts csv_file openfile) ; Export Polyline Data
;;            pBe Sep 2018            ;;
  (if (and
        (setq all_data nil
              ss       (ssget '((0 . "LWPOLYLINE")))
            (repeat (setq i (sslength ss))
              (setq e     (ssname ss (setq i (1- i)))
                     ent   (entget e)
                    area  ( / (vlax-curve-getarea e) (* 12 12))
                     data  (mapcar '(lambda (d)(cdr (assoc d ent))) '( 8 70 5))
                    pts   (mapcar 'cdr
                                  (vl-remove-if-not
                                    '(lambda (d)
                                       (= 10 (car d))
                                    ent
        (setq all_data
                       (cons
                         (list
                (cond
                                      ((null (setq ssText (ssget "_CP" pts '((0 . "TEXT")))))    (getvar 'dwgprefix)
                                        (vl-filename-base (getvar 'dwgname))
                                       ((= (sslength ssText) 1)
                                            (cdr (assoc 1 (entget (ssname ssText 0))))
                                       ((substr
                       (apply 'strcat
                          (mapcar '(lambda (st)
                                     (strcat " | " st))
                            (vl-sort
                              (mapcar '(lambda (s)
                                         (cdr (assoc 1 (Entget s)))
                                      (vl-remove-if 'listp (mapcar 'cadr (ssnamex ssText)))
                              (function (lambda (a b)
                                          (< a b)
                           4
                               area
                               (car data)
                               (if (zerop ( logand 1 (cadr data))) "No" "Yes")
                                  (caddr data)
                         all_data
               all_data
            (setq csv_file (getfiled "Save CSV File"
                                     (strcat
                                       (getvar 'dwgprefix)
                                       ".csv"
                                     "csv"
                                     45
        (progn
          (setq openfile (open csv_file "w"))
          ;(write-line
            ;"Text inside polyline,Polyline Area (sf),Layer,Closed,Handle"
            ;openfile
          (foreach itm (vl-sort all_data
                                '(lambda (a b) (< (Cadr a) (cadr b)))
            (write-line
              (Strcat (Car itm)
                      (strcat (rtos (Cadr itm) 2 2))
                      (caddr itm)
                      (cadddr itm)
                      (last itm)
              openfile
          (close openfile)
          (startapp "notepad" csv_file)
  (princ)
Replies (10)
Message 2 of 11
dlanorh
Try the attached.
I am not one of the robots you're looking for
Message 3 of 11
pbejse
@Anonymous wrote:
 ...first column having the name of the file, without .DWG,
...the second column would contain the area of each individual closed polyline,
...the third column would contain the layer name.
I'm not sure but are you wanting to run a  lisp program on more that one file? hence first column as filename?
one file	499.888		ThatAreaLayer
		4789.074	ThisAreaLayer
another file	4498.996	ThisAreaLayer
		3101.664	OtherLayer
other file	6916.215	bananaLayer
		61722.25	kakarotLayer
		4498.996	ThatAreaLayer
		3101.664	ThisAreaLayer
If so
(defun c:ECPA ( / Layers&Area ss n e objprop csv_file openfileforwrite drawgname)
  (if
      	(setq Layers&Area nil
	       ss (ssget '((0 . "LWPOLYLINE,POLYLINE") (-4 . "&") (70 . 1))))
		(progn
		  	(repeat (setq n (sslength ss))
			  	(setq e (vlax-ename->vla-object (ssname ss (setq n (1- n)))))
			  	(setq objprop (mapcar '(lambda (pr)
					   		(vlax-get e pr)) '("Layer" "Area" )))
			  	(setq Layers&Area
			  			(if (not (setq update (assoc (car objprop) Layers&Area)))
				  			(cons objprop Layers&Area)
						  	(subst (list (car objprop) (+ (cadr objprop)(cadr update)))
							       update 	Layers&Area)
		  (if (setq csv_file (getfiled "Save CSV File"
                                     (strcat
                                       (getvar 'dwgprefix)
                                       (setq drawgname (vl-filename-base (getvar 'dwgname)))
                                       ".csv" )  "csv"
                                     45
		  	(progn
			  (setq openfileforwrite (open csv_file "a"))
			  (foreach data (vl-sort Layers&Area '(lambda (a b)(< (Car a)(car b))))
			    (write-line
			    	 (strcat
				   drawgname  ","
				   		(rtos (cadr data) 2 3)  ","
				   			(car data)) openfileforwrite)
			    	(if (snvalid drawgname)
				  	(setq drawgname ""))
			  (write-line "" openfileforwrite)
			  (close openfileforwrite)
  (princ)
HTH
EDIT: oops, i read thru the post again and looked at based on dlanorh post , i missed the "individual" areas.
I'll post another one...
Like this maybe?
one file	ThatAreaLayer	499.888
				5623.12
				7845.25
		Total		13968.3
		ThisAreaLayer	499.888
				123.45
				1290.00
another file	ThisAreaLayer	4498.996
		OtherLayer	3101.664
other file	bananaLayer	6916.215
				856.26
		Total		7772.48
		kakarotLayer	61722.25
		ThatAreaLayer	61722.25
				4583.2
		Total		66305.4
		ThatAreaLayer	3101.664
Thoughts?
Message 4 of 11
pbejse
command: ECPA
				5623.12
				7845.25
				123.45
				1290.00
		Total Areas by Layer
		ThatAreaLayer	13968.3
		ThisAreaLayer	1913.34
other file bananaLayer 6916.215 856.26
kakarotLayer 61722.25 ThatAreaLayer 61722.25 4583.2 Total Areas by Layer bananaLayer 7772.48 kakarotLayer 61722.25 ThatAreaLayer 3101.664
HTH
Message 5 of 11
bit_Cad2018
this was very use full for me.
thanks
can you please add code for inside text export with coordinates
Message 6 of 11
devitg
Did you try DATEXTRACTION  at the command line........
No lisp needed
Message 7 of 11
bit_Cad2018
Sir i have many closed polyline and inside polyline survey number. this lisp area export i want help for which survey number area is.
i attach sample file please see
Message 8 of 11
devitg
Some like it??
(DEFUN LIST#2CVS  (LST) ;_01
  (APPLY 'STRCAT
         (CONS (RTOS (CAR LST))
               (MAPCAR '(LAMBDA (STR) (STRCAT "," (RTOS STR 2 2)))
                       (CDR LST)
                       ) ;_mapcar
               ) ;_cons
         ) ;_apply
;;            pBe Sep 2018            ;;
   (setq poly-sample (ssname  (ssget ":S" '((0 . "LWPOLYLINE,POLYLINE") (-4 . "&") (70 . 1)))0))
           (setq poly-layer (cdr (assoc 8 (entget poly-sample))))
;;;	  (setq      ss (ssget "x"(list (cons 0  "LWPOLYLINE,POLYLINE") (cons 8 poly-layer) (cons -4  "&") (cons 70  1))))
  (if (and
        (setq all_data nil)
               ;ss       (ssget '((0 . "LWPOLYLINE")))
                     ent   (entget e)
                    area  ( / (vlax-curve-getarea e) (* 1 1))
                    pts   (mapcar 'cdr
                                  (vl-remove-if-not
                                    '(lambda (d)
                                       (= 10 (car d))
                                    ent
        (SETQ ALL_DATA
               (CONS
                 (LIST
                   (COND
                     ((NULL (SETQ SSTEXT (SSGET "_CP" PTS '((0 . "TEXT")))))
                      (GETVAR 'DWGPREFIX)
                      (VL-FILENAME-BASE (GETVAR 'DWGNAME))
                     ((= (SSLENGTH SSTEXT) 1)
                      (CDR (ASSOC 1 (ENTGET (SSNAME SSTEXT 0))))
                     ((SUBSTR
                        (APPLY 'STRCAT
                               (MAPCAR '(LAMBDA (ST)
                                          (STRCAT " | " ST))
                                       (VL-SORT
                                         (MAPCAR '(LAMBDA (S)
                                                    (CDR (ASSOC 1 (ENTGET S)))
                                                 (VL-REMOVE-IF 'LISTP (MAPCAR 'CADR (SSNAMEX SSTEXT)))
                                         (FUNCTION (LAMBDA (A B)
                                                     (< A B)
                        4
                   AREA
                   (CAR DATA)
                   (IF (ZEROP (LOGAND 1 (CADR DATA)))
                     "No"
                     "Yes")
                   ;(CADDR DATA)
                   (LIST#2CVS(cdr (assoc 10 (entget (ssname SSTEXT   0)))))
                 ALL_DATA
               all_data
                                     (strcat
                                       (getvar 'dwgprefix)
                                       ".csv"
                                     "csv"
                                     45
        (progn
          ;(write-line
            ;openfile
            (write-line
              (Strcat (Car itm)
                      (caddr itm)
                      (cadddr itm)
                      (last itm)
              openfile
          (close openfile)
  (princ)
;|«Visual LISP© Format Options»
(180 2 1 0 nil "end of " 100 20 2 2 nil nil T nil T)
;*** DO NOT add text below the comment! ***|;
Message 9 of 11
bit_Cad2018
as you attach csv result is awesome but i try black csv create
Please see attached Clip
After lisp loaded      ; error: extra right paren on input          this error show in command line
Message 10 of 11
devitg
Solved , try it
Message 11 of 11
bit_Cad2018
ERROR not show
only blank excel create
