exploding certain entities in all block reference lisp
Brian.TsaiF883G
Brian.TsaiF883G
working from
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/any-lisp-to-delete-all-dimensions-fr...
i modified the codes to
sorry, i still don't understand
basically i modified the codes to
(defun c:blitz2  (/ aDoc)
      (vl-load-com)
      (setq aDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
      (vlax-for blk (vla-get-blocks aDoc)
      (if
            (and
                  (eq :vlax-false (vla-get-isXref blk))
                  ;(eq :vlax-false (vla-get-isLayout blk))
                  (not (wcmatch (vla-get-name blk) "`*D*"))
                 (vlax-for dim blk
                       (if (wcmatch
                                 (vla-get-ObjectName dim)
                                 "AcDb*Dimension")
                             (vla-explode dim))
      (vla-regen aDoc acAllViewports)
      (princ)
however, it doesn't work for dimensions entity
after some experimenting, it works for polylines when i change
"AcDb*Dimension")
to
"AcDb*Polyline")
can anyone help?
Moshe-A
@Brian.TsaiF883G  hi,
Apparently (vla-explode) function does not work on dimensions. so to solved your request you need to copy the dimension by means of (vla-copyObjects) to model space and call (command "explode") collect all extracted objects and (vla-copyObjects) back to the block.
Moshe
Moshe-A
@Brian.TsaiF883G ,
check this
enjoy
Moshe
(vl-load-com); load activex support
(defun c:blitz2  (/ aDoc AcDbBlkTblRec AcDbEntity ename obj^ ctr lst)
 (setvar "cmdecho" 0)
 (command "._undo" "_begin")
 (setq ctr 0)
 (vlax-for AcDbBlkTblRec (vla-get-blocks aDoc)
  (if (and
        (eq :vlax-false (vla-get-isXref AcDbBlkTblRec))
        (not (wcmatch (vla-get-name AcDbBlkTblRec) "`*Model_Space,`*Paper_Space[#],`*D*"))
   (progn
    (setq ctr 0)
    (vlax-for AcDbEntity AcDbBlkTblRec
     (if (wcmatch (vla-get-ObjectName AcDbEntity) "AcDb*Dimension")
      (progn
       (setq ename (entlast) obj^ nil)
       (vlax-invoke aDoc 'CopyObjects (list AcDbEntity) (vla-get-ModelSpace aDoc)) ; copy to model space
       (command ".explode" (entlast))
       (while (setq ename (entnext ename))
	(setq obj^ (cons (vlax-ename->vla-object ename) obj^))
       (vlax-invoke aDoc 'CopyObjects obj^ AcDbBlkTblRec) ; copy/back to block
       (foreach o obj^
	(vla-delete o)
        (vlax-release-object o)
       ); foreach
       (vla-delete AcDbEntity) ; delete dimension
       (setq ctr (1+ ctr))
      ); progn
     ); if
     (vlax-release-object AcDbEntity)
    ); vlax-for
   ); progn
  ); if
  (if (> ctr 0)
   (setq lst (cons (cons (vla-get-name AcDbBlkTblRec) ctr) lst) ctr 0)
  (vlax-release-object AcDbBlkTblRec)
 ); vlax-for
 (vlax-release-object aDoc)
 (command "._undo" "_end")
 (setvar "cmdecho" 1)
 (if (not lst)
  (princ "\nNo nested dimensions found to explode.")
  (foreach item lst
   (princ (strcat "\nBlock \"" (car item) "\", " (itoa (cdr item)) " dimension(s) exploded."))
 ); if
 (princ)
); c:blitz2
Brian.TsaiF883G
Why are you so awesome? ~~~~
Thank you very much 🙂
Brian.TsaiF883G
Now, I am trying to remove all "KS_BOLT" (non-autocad entity)  by replacing
to
(if (wcmatch (vla-get-ObjectName AcDbEntity) "Ks_Bolt")
KS_BOLT have the following info I extracted from 'VDumpit' from https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/exploding-certain-entities-in-all-bl...
I am able to select the correct quantity of KS_BOLT but i cannot execute explode or erase command on those non-AutoCAD entities. Does it need some special codes for non_AutoCAD entities?
Select Entity to Dump; IKs_ComBolt: IKs_ComBolt Interface
; Property values:
; Application (RO) = #<VLA-OBJECT IAcadApplication 00007ff726181e30>
; AreaClassName (RO) = ""
; BoltCoatingType = 2
; BoltDisplay = -1
; BoltMountingSpaceFootLength (RO) = 0.0
; BoltMountingSpaceFootWidth (RO) = 0.0
; BoltMountingSpaceHeadLength (RO) = 0.0
; BoltMountingSpaceHeadWidth (RO) = 0.0
; BoltPartlist = -1
; BoltStyleName = "8.8S-GALV"
; Count = 1
; CounterSunk = 0
; DetailStyleName (RO) = ""
; Diameter = 16.0
; DiskInnerDiameter = 18.0
; DiskOuterDiameter = 32.4
; DiskThick = 3.1
; DisplayClassName (RO) = ""
; Document (RO) = #<VLA-OBJECT IAcadDocument 000002811f8aea08>
; EntityTransparency = "ByLayer"
; FamilyClassName (RO) = ""
; FootThick = 16.0
; FreeDescriptionName (RO) = "NONE"
; GripMax (RO) = 174.0
; GripMin (RO) = 164.0
; Handle (RO) = "3F922"
; HasExtensionDictionary (RO) = 0
; HeadThick = 11.0
; Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 0000028185511b98>
; Inbus = 0
; InsertPoint (RO) = (-451.0 2677.0 -5.65455e-13)
; ItemNumber = "025"
; KeySize = 27.0
; KlemmLength = 153.188
; Layer = "PS_BOLT"
; Length = 180.0
; LengthAddition = 0.0
; Linetype = "ByLayer"
; LinetypeScale = 1.0
; Lineweight = -1
; Material = "ByLayer"
; MaterialIndex = 3002
; MountingBolt = 0
; Name = "M16 x 180 8.8/S GALV"
; Note1 = ""
; Note2 = ""
; NutDisplay = -1
; NutPartlist = 0
; ObjectID (RO) = 150
; ObjectName (RO) = "Ks_Bolt"
; OwnerID (RO) = 71
; PalNutDisplay = 0
; PalNutPartlist = 0
; PartOrigin (RO) = 0
; PlotStyleName = "Color_4"
; PosNumber = ""
; SafetyNutKeySize = 0.0
; SafetyNutThick = 0.0
; ShipNumber = ""
; Tension = 0.0
; ThreadedRod = 0
; TotalCount (RO) = 0
; TrueColor = #<VLA-OBJECT IAcadAcCmColor 0000028185511c50>
; Visible = -1
; Washer2Display = 0
; Washer2Partlist = -1
; WasherDisplay = -1
; WasherPartlist = -1
; WedgeWasher2Display = 0
; WedgeWasher2Partlist = 0
; WedgeWasherDisplay = 0
; WedgeWasherPartlist = 0
; Weight (RO) = 0.381242
; Xaxis (RO) = (-0.0522163 0.998636 2.03474e-16)
; Yaxis (RO) = (-6.87954e-16 -2.39723e-16 1.0)
; Methods supported:
; ArrayPolar (3)
; ArrayRectangular (6)
; BuildName ()
; CalculateWeight (1)
; Copy ()
; Delete ()
; GetBoundingBox (2)
; GetExtensionDictionary ()
; GetInsertUcs (1)
; GetMidLineUcs (1)
; GetObjectDisplayMode ()
; GetXData (3)
; Highlight (1)
; IntersectWith (2)
; Mirror (2)
; Mirror3D (3)
; Move (2)
; RecomputeBoltLength ()
; RetrieveGeometry (1)
; Rotate (2)
; Rotate3D (3)
; ScaleEntity (2)
; SetObjectD
isplayMode (1)
; SetPartOrigin (1)
; SetXData (2)
; TransformBy (1)
; Turn ()
; Update ()
Moshe-A
"Does it need some special codes for non_AutoCAD entities?"
before you rush to change the code with other objects first check it manually (try exploding them)
Custom AutoCAD objects need to support any functionality it needed and that's include the explode function.
if you can not explode KS_BOLT object then the programmer did not implement it 😀
Moshe
Brian.TsaiF883G
Yes it can be exploded.
i tried replacing line 22
 to
(command ".erase" (entlast))
but it doesn't erase it at all
