I have a 3D model assembly saved as a STEP file created in a different 3D CAD application (Creo). When I import the model into AutoCAD it comes in fine, but all assemblies and sub-assemblies from the original model come in as blocks and nested blocks.
I need to explode all the 'parent' blocks, but keep the lowest level nested blocks as blocks.
This can be done manually, but sometimes there are a number of levels of nested blocks and it's not clear in AutoCAD how many levels there are.. so you never know when you've exploded the lowest level block until the properties state 'surface' or '3D solid'. There is also a lot of assemblies (nests) in the model and I have a few models to apply this to!
I've seen there are ways of exploding only nested blocks, but this is the opposite to what I want to do. 'Burst' is not necessary as there are no attributes in the blocks.
Anyone ever tried this?
