Explode blocks!
Explode blocks!
Explode blocks!
(defun C:delbl ()
(setq a (ssget '((0 . "INSERT"))))
(command "_.explode" a "")
(princ)
I am trying to explode the blocks in my drawing, but after selecting the blocks, it exploded only one objects
for example,  " delbl" found 4 blocks(objects) but exploded only one, and the remaining blocks I have to continue to "delbl" and one block exploded again......Anybody can tell me the reason why?
I still can use cad command "explode" to explode them by manual. They can be exploded!
I found the solution, thanks for concerning!
dlanorh
@Anonymous wrote:
(defun C:delbl ()
(princ)
(defun C:delbl (  / a cnt ent)
(repeat (setq cnt (sslength a))
  (setq ent (ssname a (setq cnt (1- cnt))))
  (command "_.explode" ent "")
(princ)
I am not one of the robots you're looking for
cadffm
Read your EXPLODE Help[F1]  and you will see:
AutoDESK: Usual and it is as designed! (in this case "Script" means 'automation' )
My explaination:
In automatation autocad starts some commands in an older instead of the current version of a command.
 (for compatibility with older scripts or for scripts that should work with newer and older versions)
See also. INITCOMMANDVERSION (AutoLISP)
(defun C:explbl ()
  (if (setq a (ssget '((0 . "INSERT"))))
       (progn (initcommandversion 2)(command "_.EXPLODE" a ""))
(princ)
Sebastian
