Explode all selected blocks containing a specific layer
Migumby
Migumby
I’m looking for a lsp that will explode all selected blocks that contain a layer named “text tags”.
Is such a thing even possible?
hmsilva
Hi Migumby,
if I have understood your goal, perhaps something like this...
(vl-load-com)
(defun c:demo (/ i lst lst1 name obj ss)
  (or acdoc (setq acdoc (vla-get-activedocument (vlax-get-acad-object))))
  (if (setq ss (ssget "_:L" '((0 . "INSERT"))))
    (progn
      (repeat (setq i (sslength ss))
        (setq obj  (vlax-ename->vla-object (ssname ss (setq i (1- i))))
              name (vla-get-effectivename obj)
        (if (not (vl-position name lst))
          (setq lst (cons name lst))
      (vlax-for blk (vla-get-blocks acdoc)
        (if (and (= (vla-get-islayout blk) :vlax-false)
                 (= (vla-get-isxref blk) :vlax-false)
                 (vl-position (setq name (vla-get-name blk)) lst)
          (vlax-for obj blk
            (if (and (= (vla-get-layer obj) "text tags")
                     (not (vl-position name lst1))
              (setq lst1 (cons name lst1))
      (if lst1
          (if (and (vl-position name lst1)
                   (not (vl-catch-all-error-p (vl-catch-all-apply 'vlax-invoke (list obj 'explode))))
            (vla-delete obj)
  (princ)
Hope this helps,
Henrique
Migumby
Hello Henrique,
for some reason I cant get this lsp to work.
It doesnt give me any errors on loading or executing.
I'm attaching an example of the blocks that I would want exploded.
thank you for all of your help.
hmsilva
Hi Migumby,
try to change
;;to
(= (strcase (vla-get-layer obj)) "TEXT TAGS")
Hope this helps,
Henrique
Migumby
Great!
That did it!
Thank you very much
hmsilva
You're welcome, Migumby!
Glad I could help
Henrique
