Exclude Layers via a Wildcard
David_Prontnicki
David_Prontnicki
Hi everyone,
I am trying to figure how to select layers via a wildcard. In the code below I am selecting all the layers in a specific XREF and changing the plotstyle. There are specific layers that I would like to exclude. I have about 10 easement layers and do not want to have to list each layer; they all start with V-EASE, so I would like to say, anything that starts with V-EASE, exclude. The code below with the * does not work, not sure how to do that.
Also If anyone has a better way to do what I am doing overall, I am all ears.
(defun c:Test5 (/ ActDoc)
(vlax-for Lay
;;; Get layers from active document
    (vla-get-Layers
        (setq ActDoc (vla-get-ActiveDocument (vlax-get-Acad-Object))
        ) ;_ end of setq
    ) ;_ end of vla-get
;;; Plotstyle control for C-BASE
    (if
        (and (= (vl-string-search "C-BASE|" (vla-get-Name Lay)))
            (not (member (strcase (vla-get-name Lay)) '("C-BASE|V-PROP-SBACK-TEXT"
        					                            "C-BASE|V-PROP-DEED-TEXT"
        					                            "C-BASE|V-BNDY-TSHP-TEXT"
        					                            "C-BASE|V-ESMT-*"))
            ) ;_ end of not
        ) ;_ end of and
    (vla-put-plotstylename Lay "G02060")
    ) ;_ end of if for C-BASE
) ;_ end of vlax-for
(vla-Regen ActDoc acActiveViewport)
(princ)
) ;_ end of defun
cadffm
Use wcmatch for comparing.
Sebastian
David_Prontnicki
Thank you, I have played with the wcmatch but have been unable to figure out the format for listing multiple items. How do you do that? Separated by a comma doesn’t work nor does just listing.
cadffm
Comma works, i am pretty sure.
And for multiple conditions you can use COND too.
(wcmatch (strcase LAYER) "LA1,MYLAY,ALL*")
Sebastian
doaiena
Try this:
(defun c:test (/ actDoc layLst)
  (setq layLst ("C-BASE|V-PROP-SBACK-TEXT" "C-BASE|V-PROP-DEED-TEXT" "C-BASE|V-BNDY-TSHP-TEXT" "C-BASE|V-ESMT-*"))
  (vlax-for lay	(vla-get-Layers (setq actDoc (vla-get-ActiveDocument (vlax-get-Acad-Object))))
    (if	(and (= (vl-string-search "C-BASE|" (vla-get-Name lay)))
	     (not (member (strcase (vla-get-name lay)) layLst))
	     (not (wcmatch (strcase (vla-get-name lay)) "*V-EASE*"))
      (vla-put-plotstylename lay "G02060")
  (princ)
) ;defun
David_Prontnicki
Ooohhh, I had a space after each comma. That might have been the issue. I will give this a try shortly and let you know. Thank you very much.
David_Prontnicki
Hi I tried your idea, I had to add a ' to the beginning of the list to make it
(setq layLst '("C-BASE|V-PROP-SBA...
It runs but does not exclude the V-ESMT layers. They are still changing. Any Suggestions?
****** Nevermind ******* It was a spelling mistake. 🙂
