Excel Cell Reader
i tried using this lisp, i have to fill title block for which i already have a lisp program which asks for values such as
project name
name
date
and i want to use excel to enter the values, i tried customizing above program but it says theres syntax error and i am not able to figure out what i have done wrong
;--- Excel Cell Reader Sub-Routine
;--- by Leonard Lorden
;--- July 26, 2017
;--- Routine to OPEN an existing Excel file (best to confirm filename & path prior to calling)
;--- Call routine with path & filename (Example: OpenExcel "C:/Test.xlsx")
;--- File will be opened hidden
(defun OpenExcel "Info.xlsx"
(setq MyFile (findfile "Info.xlsx")) ;double check file exists at location
(if (/= Myfile nil) ;nil = file not found
(progn ;if file found open it
(setq MyXL (vlax-get-or-create-object "Excel.Application")) ;find Excel application
(vla-put-visible MyXL :vlax-false) ;hide application from view
(vlax-put-property MyXL 'DisplayAlerts :vlax-false) ;hide Excel alerts
(setq MyBook (vl-catch-all-apply 'vla-open (list (vlax-get-property MyXL "WorkBooks") MyFile)))
) ;return - MyFile = nil if file not found
;--- Routine to set Worksheet Tab
;--- Call using GetTab "Sheet1" (Example: GetTab Sheet1)
;--- If MySheet = nil on return then requested TAB not found in Excel file or Excel file was not open
(defun GetTab "Sheet1"
(if (/= MyXL nil) ;ensure file is open
(progn ;if it is then...
(setq MySheet (vl-catch-all-apply 'vlax-get-property (list (vlax-get-property myBook "Sheets") "Item" MyTab)))
(if (not (vl-catch-all-error-p MySheet)) ;if requested tab found then...
(vlax-invoke-method MySheet "Activate") ;set the desired active tab
(setq MySheet nil))) ;if tab not found then nil MySheet
(setq MySheet nil)) ;if file wasn't open then nil MySheet
MySheet) ;return with Mysheet status
;--- Routine to READ an Excel Cell on the current active tab
;--- Call using GetCell "Cell Name" (Example: GetCell A1)
;--- MyCell returns cell value (nil = empty)
(defun GetCell "C1"
(setq MyRange (vlax-get-property (vlax-get-property MySheet 'Cells) "Range" ExCell))
(setq MyCell (vlax-variant-value (vlax-get-property MyRange 'C7))))
(setq MyCell nil)) ;nill cell value if file not open
MyCell) ;return with cell value
;--- Routine to CLOSE Excel file & Session
;--- Assumes previously opened with OpenExcel function
(defun CloseExcel
(vl-catch-all-apply 'vlax-invoke-method (list MyBook "Close"))
(vl-catch-all-apply 'vlax-invoke-method (list MyXL "Quit"))
(vl-catch-all-apply 'vlax-release-object MyCell)
(vl-catch-all-apply 'vlax-release-object MyRange)
(vl-catch-all-apply 'vlax-release-object MySheet)
(vl-catch-all-apply 'vlax-release-object MyBook)
(vl-catch-all-apply 'vlax-release-object MyXL)
(setq MyFile nil MyXL nil MyBook nil MySheet nil MyRange nil
MyTab nil MyCell nil ExCell nil) ;clear variables from memory
(gc) ;garbage cleanup
) ;return
