eTransmit storage folder
aosrom
aosrom
Hi All.
I like that when I open a drawing, a auto-loaded vlisp, makes the settings to the DWG folder.
To do this I change the registers with sequences like this
(vl-registry-write
  (strcat
    "HKEY_CURRENT_USER\\Software\\Autodesk\\AutoCAD\\" StVer "\\" AcadVer "\\Profiles"
    Profil "\\Dialogs\\XattachFileDialog"
  ) ;_ end of strcat
  "InitialDirectory"
  DwgPath
) ;_ end of vl-registry-write
Someone can help me with the register key for the default folder where the archives are placed?
Many thanks,
Ranjit_Singh
I believe etransmit destination folder is stored at following location
(vl-registry-read (strcat "HKEY_CURRENT_USER\\" (vlax-machine-product-key) "\\ETransmit\\setups\\Standard")
                  "DestFolder"
To update the folder value
(vl-registry-write (strcat "HKEY_CURRENT_USER\\" (vlax-machine-product-key) "\\ETransmit\\setups\\Standard")
                   "DestFolder"
                   "C:\\Users\\username\\Desktop"; desired directory here
aosrom
Yes.
With (vlax-product-key) instead of (vlax-machine-product-key) is also ok for versions older than 2012.
Thanks Ranjit.Singh,
Ranjit_Singh
You are welcome. Glad to have helped.
