ESC key in -LAYER command
JackTryMC
JackTryMC
Hi, i've got problem with putting "escape key" between two commands. I generate name of layer and x y coordinates from excel. It looks like:
_.-LAYER _set nameofmylayer "here i want to brake command -layer  by escape and insert next command circle"
_.circle x.,y. 2
^C^C, nil, #\ESCAPE etc doesn't work.
paullimapa
Why not just use extra spaces to represent enter to complete the layer command before starting another command?
Paul Li
IT Specialist
@The Office
Kent1Cooper
Is this for a command macro, or in a Script file, or...?
Layer names can have spaces, so adding spaces could be problematic.  If it's a macro, ; is Enter, so try:
_.-LAYER _set nameofmylayer;;_.circle x.,y. 2
[But if the Layer name contains spaces, wrap it in double-quotes.]
If it's a Script file, try:
_.circle x.,y. 2
with that blank line between the commands.
Kent Cooper, AIA
JackTryMC
I want to "generate" this command in excel and paste directly to autocad command line box.
paullimapa
You can use lisp code
(command “_.-LAYER” “_set” “nameofmylayer” “” “_.Circle”)
Paul Li
IT Specialist
@The Office
Sea-Haven
Watch out for double quotes they can be left and right look real close at your post. using concatenate in excel may be helpful and char(34) for a dbl quote.
For JacktryMc are you looking at making more than 1 at a time then look at reading a csv file or read direct from excel. Solved: Lisp to add vertices to polyline - Autodesk Community - AutoCAD
