Error
Error
jinkinglee
Error
jinkinglee
The following is displayed. How do I find and fix it? Attached CoatMuller.lsp
[CHECKING TEXT CoatMuller.lsp loading ...]
; Warning: redefinition of built-in symbol: T
; Warning: too few arguments: (* ERROR *)
; Check done.
Thank you.
Jin
Ranjit_Singh
Right here you are binding in-built symbol T to some reas number. Nothing wrong with it, but it could screw up your LISP environment. Review and fix it.
(setq T (polar Ad_1 (angle Ad_1 F_D) (cm_inch 3.5)))
Secondly, *error* needs an argument at the very end here
   (*error*); change this to (*error* "end")
) ;_ end of defun
you also need to fix your error trap to ignore reporting error when message is "end'. Search forums for error trap.
