Error while retrieving block attributes
Lauri_LehtomakiUJAHS
I'm trying to loop through block and retrieve attributes into a list of dotted pairs (tag . value).
In row 20 the code runs into an error "error: bad function: "VALUE"" where VALUE is the attribute value. However if I do this row by row from command prompt I'm able to store these values without any errors. While loop and cond seems to work fine. What am I missing here?
(defun c:listAttributes (/ attributes endseq currentBlock entTemp keyword attTag attValue)
  (setq currentBlock (entget (car (entsel))))
  (setq endseq nil)
  (setq entTemp currentBlock)
  (while (null endseq)
    (setq entTemp (entget (entnext (cdr (assoc -1 entTemp)))))
    (setq keyword (cdr (assoc 0 entTemp)))
    (cond
      ( (= keyword "ATTRIB")
          (setq attValue ((cdr (assoc 1 entTemp))))
          (setq attTag (cdr (assoc 2 entTemp)))
          (setq attributes (append attributes (list (cons attTag attValue))))
      ( (= keyword "SEQEND")
        (setq endseq T)
      (t nil)
pbejse
@Lauri_LehtomakiUJAHS wrote:
...In row 20 the code runs into an error "error: bad function: "VALUE"" where VALUE is the attribute value.  While loop and cond seems to work fine. What am I missing here?
You had one too many parenthesis
the Fix
  (setq endseq nil)
    (cond
          (setq attValue (cdr (assoc 1 entTemp)))
        (setq endseq T)
      (t nil)
  ) attributes
HTH
Thanks! Seems to be too obvious to detect.
pbejse
We all been there.
You are welcome @Lauri_LehtomakiUJAHS
