; error: too many arguments
bustr
bustr
This is happening after I post the name of the lisp to the command line. I can't spot the error in it. It has always worked before. The lisp is supposed to search out text and attribute values and replace them. Can anyone spot the error?
(defun c:BUBBLER01 ()
(setq ss_blk (ssget "x" '((0 . "INSERT") (66 . 1))))
(if ss_blk
(progn
(setq lst_blk (sel2lst ss_blk))
(foreach en_blk lst_blk
(setq lst_atts (att2lst en_blk))
(setq str_line "")
(foreach en_atts lst_atts
(setq str_line (getval 1 en_atts))
(if (not (wcmatch str_line "*/*/*"))
(progn
(setq str_line (strchg str_line *01* * 5555501*))
(setq str_line (strchg str_line *02* * 5555502*))
(setq str_line (strchg str_line *03* * 5555503*))
(setq str_line (strchg str_line *04* * 5555504*))
(setq str_line (strchg str_line *05* * 5555505*))
(setq str_line (strchg str_line *06* * 5555506*))
(setq str_line (strchg str_line *07* * 5555507*))
(setq str_line (strchg str_line *08* * 5555508*))
(setq str_line (strchg str_line *09* * 5555509*))
(setq str_line (strchg str_line *10* * 5555510*))
(setq str_line (strchg str_line *11* * 5555511*))
(setq str_line (strchg str_line *12* * 5555512*))
(setq str_line (strchg str_line *13* * 5555513*))
(setq str_line (strchg str_line *14* * 5555514*))
(setq str_line (strchg str_line *15* * 5555515*))
(setq str_line (strchg str_line *16* * 5555516*))
(setq str_line (strchg str_line *17* * 5555517*))
(setq str_line (strchg str_line *18* * 5555518*))
(setq str_line (strchg str_line *19* * 5555519*))
(setq str_line (strchg str_line *20* * 5555520*))
(setq str_line (strchg str_line *21* * 5555521*))
(setq str_line (strchg str_line *22* * 5555522*))
(setq str_line (strchg str_line *23* * 5555523*))
(setq str_line (strchg str_line *24* * 5555524*))
(setq str_line (strchg str_line *25* * 5555525*))
(setq str_line (strchg str_line *26* * 5555526*))
(setq str_line (strchg str_line *27* * 5555527*))
(setq str_line (strchg str_line *28* * 5555528*))
(setq str_line (strchg str_line *29* * 5555529*))
(setq str_line (strchg str_line *30* * 5555530*))
(setq str_line (strchg str_line *31* * 5555531*))
(setq str_line (strchg str_line *32* * 5555532*))
(setq str_line (strchg str_line *33* * 5555533*))
(setq str_line (strchg str_line *34* * 5555534*))
(setq str_line (strchg str_line *35* * 5555535*))
(setq str_line (strchg str_line *36* * 5555536*))
(setq str_line (strchg str_line *37* * 5555537*))
(setq str_line (strchg str_line *38* * 5555538*))
(setq str_line (strchg str_line *39* * 5555539*))
(setq str_line (strchg str_line *40* * 5555540*))
(setq str_line (strchg str_line *41* * 5555541*))
(setq str_line (strchg str_line *42* * 5555542*))
(setq str_line (strchg str_line *43* * 5555543*))
(setq str_line (strchg str_line *44* * 5555544*))
(setq str_line (strchg str_line *45* * 5555545*))
(setq str_line (strchg str_line *46* * 5555546*))
(setq str_line (strchg str_line *47* * 5555547*))
(setq str_line (strchg str_line *48* * 5555548*))
(setq str_line (strchg str_line *49* * 5555549*))
(setq str_line (strchg str_line *50* * 5555550*))
(setq str_line (strchg str_line *51* * 5555551*))
(setq str_line (strchg str_line *52* * 5555552*))
(setq str_line (strchg str_line *53* * 5555553*))
(setq str_line (strchg str_line *54* * 5555554*))
(setq str_line (strchg str_line *55* * 5555555*))
(setq str_line (strchg str_line *56* * 5555556*))
(setq str_line (strchg str_line *57* * 5555557*))
(setq str_line (strchg str_line *58* * 5555558*))
(setq str_line (strchg str_line *59* * 5555559*))
(setq str_line (strchg str_line *60* * 5555560*))
(setq str_line (strchg str_line *61* * 5555561*))
(setq str_line (strchg str_line *62* * 5555562*))
(setq str_line (strchg str_line *63* * 5555563*))
(setq str_line (strchg str_line *64* * 5555564*))
(setq str_line (strchg str_line *65* * 5555565*))
(setq str_line (strchg str_line *66* * 5555566*))
(setq str_line (strchg str_line *67* * 5555567*))
(setq str_line (strchg str_line *68* * 5555568*))
(setq str_line (strchg str_line *69* * 5555569*))
(setq str_line (strchg str_line *70* * 5555570*))
(setq str_line (strchg str_line *71* * 5555571*))
(setq str_line (strchg str_line *72* * 5555572*))
(setq str_line (strchg str_line *73* * 5555573*))
(setq str_line (strchg str_line *74* * 5555574*))
(setq str_line (strchg str_line *75* * 5555575*))
(setq str_line (strchg str_line *76* * 5555576*))
(setq str_line (strchg str_line *77* * 5555577*))
(setval 1 str_line en_atts)
(setq ss_txtlines (ssget "x" '((0 . "TEXT"))))
(if ss_txtlines
(progn
(setq lst_txtlines (sel2lst ss_txtlines))
(setq str_line "")
(foreach en_txtlines lst_txtlines
(setq str_line (getval 1 en_txtlines))
(progn
(setval 1 str_line en_txtlines)
_gile
The code you posted is not relevant because it calls many user defined functions you do not show:
  • sel2lst
  • att2lst
  • getval
  • strchg
  • setval
Gilles Chanteau
GileCAD
GitHub
bustr
Got rid of asteriks and added code and /code. Works now.
ronjonp
