Error: malformed list on input
paulo.barreraF8J36
Message 1 of 24
paulo.barreraF8J36
Hello Everyone,
I am currently trying to create a .lisp program that automates the editing of attributes in a dynamic block. I have written the code and uploaded it to AutoCAD but am getting the error : malformed list on input. This shows up above the command line after I load it in the load/unload applications tab.
The code works by taking a csv file and separating the entries by columns. The csv file has 5 columns: Block, ID, ID_value, Attribute, Attribute_Value.
This is my first time working on AutoLISP so really anything could be wrong.
Thank you so much for your time and help.
Here is my code, I will also upload the file below:
(defun c:replaceAttributes (filePath)
(if (setq fp (open filePath "r"))
(progn
(while (setq line (read-line fp))
(if (> (length line) 0)
(progn
(setq values (mapcar 'atoi (strsplit line ",")))
(setq blockName (nth 0 values))
(setq attribName (nth 1 values))
(setq newValue (nth 2 values))
(if (setq b (ssget (list (cons 0 "INSERT") (cons 2 blockName))))
(progn
(foreach b (entget b)
(if (and (equal (cdr (assoc 2 b)) blockName) (equal (cdr (assoc 70 b)) 1))
(progn
(if (setq a (ssget (list (cons 0 "ATTRIB") (cons 8 b) (list (cons 2 attribName)))))
(progn
(setq attribs (entget a))
(if (setq index (assoc 2 attribName attribs))
(progn
(setq newAttribs (subst (cons 2 newValue) index attribs))
(entmod newAttribs)
(close fp)
(alert "Attributes replaced.")
(alert (strcat "File " filePath " not found."))
Replies (23)
Message 21 of 24
pbejse
(defun c:replaceAttributes ( / strsplit filePath fp line Alldata blockObjects index en bn attValues)
(defun strsplit ( str d_ / p)
  	(if (setq p (vl-string-position (Ascii d_) str))
	  	(cons (substr str 1 p) (strsplit (substr str (+ 2 p)) d_))
  		(list str)
(if (and
      (setq filePath (getfiled "Select Attribute Data CSV file" (getvar 'dwgprefix) "csv" 16))
      (setq blockObjects (ssget  '((0 . "INSERT")(66 . 1)(410 . "Model"))))
	(progn
		     (and
			(> (strlen line) 0)
			(setq data (strsplit line ","))
			(setq Alldata (cons data Alldata)))
    		(close fp)
	  	(and
		  Alldata
		(repeat (setq index (sslength blockObjects))
		  (setq en (ssname blockObjects (setq index (1- index))))
		  (setq bn (getpropertyvalue en "BlockTableRecord/Name"))
		    (and
		      (assoc (strcase bn) Alldata)
		    (setq attValues
			   ((lambda ( e / entData en lst)
				   (while (and (setq e (entnext e))
					       (= "ATTRIB" (cdr (assoc 0 (setq entData (entget e))))))
				        (setq lst
				            (cons (list (cdr (assoc 2 entData))
							(cdr (assoc 1 (reverse entData)))) lst
		    				) lst
		    			)  en
			(vl-some '(lambda (v / F)
				    (cond
				      ((and (eq (strcase (car v)) bn)
					    (setq f (assoc (cadr v) attValues))
						(eq (cadr f) (caddr v))
					    	(setq f (assoc (cadddr v) attValues)))
				       (setpropertyvalue en (cadddr v) (last v))
				       (setq Alldata (vl-remove v Alldata))
				 Alldata
	  );progn
  	);if
  (princ)
HTH
BTW, Will there be duplicate values of SENSOR_ID values on the blocks?
Message 22 of 24
paulo.barreraF8J36
No all the sensor ID values are different based on the plan! The value will be some abbreviated version of the company, floor number then 1-however many sensors there are. Ex. TIAA-NY-F06-001 where the 001 will range from 001 to however many sensors there are, ex, 001 - 036
Message 23 of 24
paulo.barreraF8J36
This worked perfectly! I selected all the blocks I needed then ran the command, found the file and it uploaded all of the serial numbers! Thank you so much for your help!
Message 24 of 24
pbejse
Glad to hear the code works for you and we hope you will from it.
You are very welcome @paulo.barreraF8J36
Cheers
