Announcements
Error in my code
Error in my code
Can anybody help me debug this code i wrote. Also is there a program I can use to debug my lisp?
I'm a Newbie Man Happy
(defun c:demo (/ ent flag hnd i lst ss)
   (if (setq ss (ssget "_X" (list '(0 . "INSERT") '(66 . 1))))
      (repeat (setq i (sslength ss))
         (setq hnd (ssname ss (setq i (1- i))))
         (while (and
                   (setq hnd (entnext hnd))
                   (setq ent (entget hnd))
                   (= (cdr (assoc 0 ent)) "ATTRIB")
            (if (wcmatch (strcase (cdr (assoc 2 ent))) "REV,REV*")
               (setq flag1 T)
	(setvar "tilemode" 1)
	(setq dr (getvar "dwgname"))
	(setq a (getvar "EXTMAX"))
	(setq pt1 (caddr a))
		(if
			((= pt1 0) (command "_saveas" "2010" (strcat "H:\\2D\\" dr))
		 (cond
			((> pt1 0) (setq lay1 (tblsearch "LAYER" "system"))
		       	;((= lay1 flag1) (command "_saveas" "2010" (strcat "H:\\3D\\Cadworx-Titleblock\\" dr)))
			(lay1 (command "_saveas" "2010" (strcat "H:\\3D\\Cadworx\\" dr)))
			((/= lay1 T) (command "_saveas" "2010" (strcat "H:\\3D\\Misc\\" dr)))
	(princ)
Thanks for the pointers.
LG
Replies (17)
scot-65
(if
((= pt1 0)
extra left parenthesis.
lay1is not defined before entering the COND.
Even if you define inside the COND, that line is evaluated and then
the flow skips past the rest of the cond's - meaning if the test fails,
lay1 will not be defined for successive tests.
Also, what happens if ss is nil?
Expressions past the line "setvar tilemode 1" are still evaluated, which
should not (flag1 is not set when ss is nil).
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Thanks Scot-65 for the pointers,
Im still getting an error
"; error: malformed list on input"
not sure where i have it wrong.
Satoews
Been playing around with this one even though its a bit out of my skill level, lets try this on for size.
  (setq a (getvar "extmax"))
  (setq flag1 nil)
  (setq lay1 nil)
  (if(> pt1 0)
    (setq lay1 (tblsearch "layer" "system")))
      (if (setq ss (ssget "_x" (list '(0 . "insert") '(66 . 1))))
             (while (and
                   (= (cdr (assoc 0 ent)) "attrib")
               (if (wcmatch (strcase (cdr (assoc 2 ent))) "rev,rev*")
                 (setq flag1 t)
        (cond
			((= pt1 nil) (command "_saveas" "2010" (strcat "h:\\2d\\" dr)))
		    ((and(=/ lay1 nil) (= flag1 t)) (command "_saveas" "2010" (strcat "h:\\3d\\cadworx-titleblock\\" dr)))
			((=/ lay1 nil)(command "_saveas" "2010" (strcat "h:\\3d\\cadworx\\" dr)))
			(t (command "_saveas" "2010" (strcat "h:\\3d\\misc\\" dr)))
	(princ)
Shawn T
Satoews
(defun c:demo (/ ent flag hnd i lst ss dr a pt1 lay1)
  (setq flag1 0)
  (setq lay1 0)
  (if(> pt1 0)
             (while (and
                 (setq flag1 t)
        (cond
		    ((and(=/ lay1 0) (= flag1 t)) (command "_saveas" "2010" (strcat "h:\\3d\\cadworx-titleblock\\" dr)))
			((=/ lay1 0)(command "_saveas" "2010" (strcat "h:\\3d\\cadworx\\" dr)))
	(princ)
For some reason I can't revise my post, huh. Well I wanted to adjust a couple of things so try this one.
Shawn T
hmsilva
Hi ACER79,
let's see if I understand your goal...
Your goal is to save the current dwg in one of four different folders:
if not 3d -> "H:\\2D\\"
if 3d, test if there are a 'system' layer,
if exist a 'system' layer, and a titleblock (test attribs 'REV' or 'REV*' -> "H:\\3D\\Cadworx-Titleblock\\"
if exist a 'system' layer, and not a titleblock -> "H:\\3D\\Cadworx\\"
if none of the above tests is true, -> "H:\\3D\\Misc\\"
I'm correct?
(defun c:demo (/ a dr ent flag hnd i lay1 lst ss)
         (while (and
               (setq flag T)
         a   (getvar "EXTMAX")
         pt1 (caddr a)
   (if (> pt1 0 )
   (if (equal pt1 0 1e-8)
      (cond ((and lay1 flag) (command "_saveas" "2010" (strcat "H:\\3D\\Cadworx-Titleblock\\" dr)))
            (T (command "_saveas" "2010" (strcat "H:\\3D\\Misc\\" dr)))
   (princ)
Hope this helps,
Henrique
@hmsilva wrote:
Hi ACER79,
I'm correct?
Hope this helps,
Henrique
Yes that is exactly correct!!!
pbejse
@Anonymous wrote:
......Also is there a program I can use to debug my lisp?
 LG
Command prompt : Vlide
Menubar: Tools-> Autolisp - > Visual Lisp Editor
Ribbons: Manage-> Appication -> Visual Lisp Editor
Inside Vlide: Debug -> Break on Error
------>  if error -> Ctrl+F9 [ will highlight where the error is ]
------>  to step out of error -> Ctrl+Q
HTH
hmsilva
@Anonymous wrote:
@hmsilva wrote:
Hi ACER79,
I'm correct?
Hope this helps,
Henrique
Ok, I did understood your goal...
And the revised code did worked as expected?
[Off-Topic]
@pbejse
Happy to 'see' you my friend! 🙂
Cheers
Henrique
I'm testing the code by dragging and dropping into the autocad drawing and this error occurs;
"error: malformed list on input"
if i load the lsp from appload it says it is loaded successfully but then unknown command when demo is typed.
hmsilva
Try the attached code...
Henrique
Satoews
Copy and paste silvas code above into notepad (not word) and save as with .lsp ext. Then follow below.
http://www.ellenfinkelstein.com/acadblog/how-to-load-an-autolisp-program/
Shawn T
Satoews
Malformed list on input :
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=3901
Shawn T
Thank you Hmsilva,
Your code works great. I added in a line of code to also change ucs to world before checking the coordinates.
Could you possibly send me your code with some comments to each line?  I'd like to get a better understanding to the code.
Much appreciated.
Tornc Thanks for the pointers!!!
Satoews
Glad I could help Smiley Happy
Shawn T
hmsilva
@Anonymous wrote:
Thank you Hmsilva,
You're welcome, ACER79!
Glad I could help.
Attached, the code with some comments...
Henrique
Man what an awesome group of guys here!!!
I hope one day i'll be able to return the favor.
LG
pbejse
@hmsilva wrote:
 [Off-Topic]
@pbejse
Cheers
Henrique
Happy to be seen my friend Smiley Happy
