ERROR IN ALL LIST IF MODIFY IN DCL
rolisonfelipe
rolisonfelipe
HOW TO TRANSFORM THE SELECTION OF THIS LIST IN TEXT INSIDE THE TEXT BLOCK
(SETQ VERBA (LIST "LIST1" "LIST2" "LIST3"))
(SETQ MES (LIST "JAN./2021" "FEV./2021" "MARÇ./2021" "MARÇ./2021" "ABRIL./2021" "MAIO./2021" "JUN./2021" "JUL./2021" "AGO./2021" "SET./2021" "OUT./2021" "NOV./2021" "DEZ./2021"))
; ERROR IN ALL LIST IF MODIFY IN DCL , THE LIST DON'T GO FOR BLOCK TEXT, IT IS LOAD, ABOUT DON'T GO FOR BLOCK TEXT
john.uhden
With my inability to understand what I think to be Spanish, I can't tell what you are trying to do.
I am so sorry.
John F. Uhden
rolisonfelipe
John F. Uhden, hello dear friend! this post is an error in a list that I have already solved, however, the error in importing data from excel, where when selecting the name of a city, which is in a cell, a1 the programming should import the sequence b1 c1 d1 e1 f1 that is given for that city, if I wanted data from a city that was on a line type a5, the data b5 c5 d5 e5 f5 would be imported, it seems that when I enter any line it is F1 the programming makes it possible to always import the sequence b1 c1 d1 e1 f1 or if I select G1 it only imports b1 c1 d1 e1 f1 ....
it seems to me that the problem is here
; ///////////////////////////////////////////////// /////////////////////////////// READ XLS COMMANDS
(DEFUN EXECUTE-LEARQXLS ()
(VL-LOAD-COM)
(NIL CELLS SETQ)
(SETQ EXCEL-APP (VLAX-CREATE-OBJECT "EXCEL.APPLICATION"))
(SETQ WB-COLLEC (VLAX-GET EXCEL-APP "WORKBOOKS"))
(SETQ ARQXLS (FINDFILE "STANDARD.XLS")); open the exel file
(IF (NOT ARQXLS)
(PROGN
(ALERT "*** XLS FILE NOT FOUND! ***")
(EXIT)
(SETQ ARQVO (VLAX-INVOKE-METHOD WB-COLLEC "OPEN" ARQXLS))
(SETQ PASTAS (VLAX-GET ARQVO "SHEETS")); select the folder
(SETQ PASTA1 (VLAX-GET-PROPERTY FOLDERS "ITEM" 1)); selects folder 1
(CELLS SETQ (VLAX-GET PASTA1 "CELLS"));
(SETQ LLNCITY '()); set var
(SETQ LLNAME '()); set var
(SETQ LLENDE '()); set var
(SETQ LLMAIL '()); set var
(SETQ LL 2)
(LE-LINE-XLS LL 10)
(SETQ NN 0)
(WHILE (OR (/ = "" (NTH 0 LXLS)))
(SETQ LLNCITY (CONS (NTH 0 LXLS) LLNCITY)); set var for data a1 excel
(SETQ LLNOME (CONS (NTH 1 LXLS) LLNAME)); set var for data b1 excel
(SETQ LLENDE (CONS (NTH 2 LXLS) LLENDE)); set var for data c1 excel
(SETQ LLMAIL (CONS (NTH 3 LXLS) LLMAIL)); set var for data d1 excel
(SETQ LL (+ LL 1))
(LE-LINE-XLS LL 10)
(SETQ LLNCITY (REVERSE LLNCITY))
(SETQ LLNAME (REVERSE LLNAME))
(SETQ LLENDE (REVERSE LLENDE))
(SETQ LLMAIL (REVERSE LLMAIL))
diagodose2009
=You separate EXCEL-function/s and Dialog.DCL-display.You develope two-programs.lsp
first-----Dcl-dialog-display.lsp
Second--Excel-Links.lsp
Third. setup-vlaxcompil1-144mini.zip/download
=One big-crash your , you do not have unload_dialog.
       action_tile("BT-CA-EMPRESA","(DONE_DIALOG 2)");
       action_tile("BT-CA-AMBAS","(DONE_DIALOG 1)");
       action_tile("BT-SAIR","(DONE_DIALOG 0)");
       action_tile("accept","(done_dialog 3)");
       action_tile("cancel","(setq acl nil)(done_dialog 4)");
       $rr=start_dialog();
       unload_dialog(edi);
=You set all varianile-names as one-wcmatch.Here is myDemo all variaible-names start with prefix=NN_*.
=I convert  your-STANDARD-MENU-TELA-CAD.DCL as String and you store the STANDARD-MENU-TELA-CAD.DCL inside STring-Variabile.
      if (!NN_MES) NN_MES="0";
      if (!NN_VERBA ) NN_VERBA="0";
      if (!NN_REVISAO ) NN_REVISAO="R0";
      if (!NN_ESCPROJJ ) NN_ESCPROJJ="1: 50";
      if (!NN_END_OBRA ) NN_END_OBRA="RUA ";
      if (!NN_CONTRATO ) NN_CONTRATO="ADD N-ª CONV+ΦNIO";
      if (!NN_PROJJ ) NN_PROJJ="0";
      if (!NN_SPROJ ) NN_SPROJ="0";
      if (!NN_CITY ) NN_CITY="0";
      if (!NN_NOME ) NN_NOME="0";
      if (!NN_ENDE ) NN_ENDE="0";
      if (!NN_MAIL ) NN_MAIL="0";
       foreach(nop,lds,set(read("dyn"),eval(read(strcat("NN_",nop)))),
                      mes=(dyn==nil)?"0":set_tile(nop,dyn));
       foreach(nop,ldc,set(read("dyn"),strcat("(SETQ NN ",nop," $value)")),
                      action_tile(nop,dyn));
 (sEtq movd ""
  movd (strcaT movd "dcl_settings : default_dcl_settings { audit_level = 0; }\n//////////////////////\nEXECUTAR_TELA_CARIMBO : dialog  ");;
  movd (strcaT movd "\n{label = \"STANDARD©2021\";\n:row{\n : boxed_column{ label=\"[ INFORME OS DADOS DA OBRA ]\";\n : popup_list {label = \"SOLICITANTE         \"	; key = \"LLNCITY\"				;fixed_width=true;width=30;edit_width =70;}\n : popup_list {label = \"TITULO PROJETO  \"		; key = \"LLPROJJ\"				;fixed_width=true;width=30;edit_width =70;}\n : popup_list {label = \"SUBTITULO           \"	; key = \"LLSPROJ\"				;fixed_width=true;width=30;edit_width =70;}\n : edit_box	{label = \"ENDERECO OBRA \"		; key = \"END_OBRA\"				;fixed_width=true;width=30;edit_width =70;}\n ");;
  movd (strcaT movd " }\n}\n:row{\n : boxed_column{ label=\"[ DADOS COMPLEMENTARES  ]\";\n : popup_list {label = \"TIPO RECURSO    \"		; key = \"VERBA\"					;fixed_width=true;width=0;edit_width =70;}	\n : edit_box	{label = \"NO.   CONTRATO   \"		; key = \"CONTRATO\"				;fixed_width=true;width=0;edit_width =70;}\n }\n}\n:column{\n : boxed_row{ label=\"[ DADOS DO DESENHO ]\";\n : popup_list {label = \"MES/ANO\"				; key = \"MES\"					;fixed_width=true;width=20;edit_width =10;alignment=centered;}	\n : edit_box	{label = \"ESCALA \"				; key = \"ESCPROJJ\"	 ");;
  movd (strcaT movd "			;fixed_width=true;width=0;edit_width =10;}\n : edit_box	{label = \"REVISAO \"				; key = \"REVISAO\"				;fixed_width=true;width=0;edit_width =10;}\n }\n}\n:column {\n :row{ label=\"\";\n : button {label = \" SAIR \"						; key = \"BT-SAIR\" ; fixed_width=true;width=15;alignment=centered;}\n : button {label = \"FORMATO AMBAS\"				; key = \"BT-CA-AMBAS\"			; fixed_width=true;width=0;alignment=centered;is_default=true;}\n : button {label = \"FORMATO STANDARD\"			; key = \"BT-CA-EMPRESA\"			; fixed_width=true;width=0;alignment=centered;is_default=true;}\n ");;
  movd (strcaT movd " spacer_1;\n }\n }\n ok_cancel;\n spacer;\n}\n "))
