; error: Function cancelled
iftikhargulmrd
iftikhargulmrd
hey all
can someone adjust error as mention on subject in attached lisp
Best Regards
dlanorh
What version of AutoCAD are you trying to run this in, Plain AutoCAD, Civil, Map?
I am not one of the robots you're looking for
hak_vz
Original code from INTLINES - draws points in all intersections of selected objects, lines, incl. self-intersections (c...  works correctly in AutoCAD.
Your code looks for function CREATEPOINTMANUAL (from Civil 3D) that is used to create point at specific location.
So instead of  CREATEPOINTMANUAL you use command POINT.
(command "_POINT" PT))
Miljenko Hatlak
iftikhargulmrd
want to use in civil 3d to create points  automatic at all intersections
regards
hak_vz
I dont't use Civil 3d but from Googling for CREATEPOINTMANUAL
(COMMAND ".CREATEPOINTMANUAL" centerpnt "<description or . >" "<elevation or (CADDR centerpnt) or . " "")
try.
(COMMAND ".CREATEPOINTMANUAL" pt "."  "." )
Miljenko Hatlak
iftikhargulmrd
sir
no problem for discerption and level civil 3d has option to turn it off,
just to mark all intersection with cogo points,
regards and appreciate
Sea-Haven
It does not matter if there points you can do everything like number, get xyz etc. Its more about what your trying to do with these points as a end result, the obvious is just put them on a layer.
