Error Code
Error Code
jyan2000
Message 1 of 10
Error Code
jyan2000
Could anyone correct this code ?
Best Regards
Victor
(defun c:sd2 ( / ss e )
(setq ofd (cond
(setvar "ofd" 74))
(if (setq ss (ssget "all"))
(repeat (sslength ss)
(setq e (vlax-ename->vla-object (ssname ss 0)))
(if (vlax-method-applicable-p e 'Offset)
'vla-offset (list e))))(list ofd (- ofd)))
(ssdel (ssname ss 0) ss)))
(princ)
Replies (9)
Message 2 of 10
hmsilva
Hi Victor,
if I understand correctly your goal...
(defun c:sd2 (/ e i x ss)
  (if (or (null ofd)
          (/= (type ofd) 'REAL)
    (setq ofd 74.)
    (repeat (setq i (sslength ss))
      (setq e (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
        (vl-every '(lambda (x) (vl-catch-all-apply 'vla-offset (list e x))) (list ofd (- ofd)))
  (princ)
Hope this helps,
Henrique
Message 3 of 10
jyan2000
Hi HmSilva,
That's perfect code which exactly what I was looking for. But, can I ask little more favourite? (See Attached file)
  • After offsetting; change previous or first PLINE to Layer name: Hidden. ; Second PLINE is to be same as the selected PLINE layer name (exp: Type_06).
  • Create a text with specific height, with, position x,y,z (165,725, 0); (contents: same as the selected PLINE Layer name; exp:Type_06)
  • Create second text with specific height, with, position x,y,z (165,560, 0); (contents: TEXT 2)
Sorry for my poor English. But, I’d really appreciate if we could do it.
Best regards
Victor
Message 4 of 10
hmsilva
Hi Victor,
instead of a .png file, post a .dwg file and I'll see what I can do...
Are you going to process only one polyline per dwg and in the current layout?
Henrique
Message 5 of 10
jyan2000
Hi Henrique,
First of all I'm really thankfull to your replay.There is the attached file. There will be single PLINE.  3rd stage might be complicated one. (can skip).
Regards
Victor.
Message 6 of 10
hmsilva
Victor,
I have a deadline to meet today, tonight I'll see what I can do...
Henrique
Message 7 of 10
jyan2000
I appreciated. Thanks a lot .
Message 8 of 10
hmsilva
Hi Victor,
Sorry, but I'm with a large workload, and I don't have much free time...
Try this 'quick and dirty' and  minimally tested 'demo', with a different approach, not using 'offset'.
The 'demo':
  • expects only one 'lwpolyline' in WCS in the dwg
  • expects the 'lwpolyline' with a layer 'xxx_#'
  • don't deals with the 'TXT_##' layer color (I could not find a relationship between the 'Type_##' layer color, and the 'TXT_##' layer color)
  • don't deals with the text style you have in the 'sample.dwg'
  • don't deals with the linetype scale in the layer 'Hidden'
Probably, don't deals with many more things!
See this 'demo' only as a starting point.
(vl-load-com)
(defun c:demo (/ *error* mk_txt adoc clay dist echo ent lay layn llpt llpt+ llpt- lpt_txt lrpt lrpt+ pl-list pos pt pts ss txt1 txt2 ulpt ulpt+ upt_txt urpt
               urpt+)
  (defun *error* (msg)
    (if clay
      (setvar 'CLAYER clay)
    (if echo
      (setvar 'CMDECHO echo)
    (vla-endundomark adoc)
    (cond
      ((not msg))
      ((member msg '("Function cancelled" "quit / exit abort")))
      ((princ (strcat "\n** Error: " msg " ** ")))
    (princ)
  (defun mk_txt (pt str)
    (entmake
      (list
        (cons 0 "TEXT")
        (cons 100 "AcDbText")
        (cons 10 pt)
        (cons 40 100.)
        (cons 1 str)
    (princ)
  (setq adoc (vla-get-activedocument (vlax-get-acad-object)))
  (vla-startundomark adoc)
  (if (and (setq ss (ssget "_X"
                           '((0 . "LWPOLYLINE") (90 . 4) (70 . 1) (-4 . "<NOT") (-4 . "<>") (42 . 0.0) (-4 . "NOT>"))
           (= (sslength ss) 1)
           (setq ent (entget (ssname ss 0)))
           (setq lay (cdr (assoc 8 ent)))
           (wcmatch lay "Type_#*")
           (setq pos (vl-string-position (ascii "_") lay))
           (setq layn (strcat "TXT" (substr lay (1+ pos))))
           (setq txt1 (strcat "Text" (substr lay (1+ pos))))
           (setq txt2 (strcat (substr lay 1 pos) " _ " (substr lay (+ pos 2))))
           (setq clay (getvar 'CLAYER))
           (setq echo (getvar 'CMDECHO))
           (setvar 'CMDECHO 0)
    (progn
      (if (or (null ofd)
        (setq ofd 74.)
      (setq pts (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) ent)))
      (setq pts (vl-sort pts
                         '(lambda (a b) (or (< (cadr a) (cadr b)) (and (= (cadr a) (cadr b)) (<= (car a) (car b)))))
      (if (< (car (nth 0 pts)) (car (nth 1 pts)))
        (setq llpt (nth 0 pts)
              lrpt (nth 1 pts)
        (setq lrpt (nth 0 pts)
              llpt (nth 1 pts)
      (if (< (car (nth 2 pts)) (car (nth 3 pts)))
        (setq ulpt (nth 2 pts)
              urpt (nth 3 pts)
        (setq urpt (nth 2 pts)
              ulpt (nth 3 pts)
      (setq pl-list (cons llpt pl-list)
            pl-list (cons (setq llpt+ (polar llpt (* pi 1.5) ofd)) pl-list)
            pl-list (cons (polar llpt+ (angle llpt lrpt) (distance llpt lrpt)) pl-list)
            pl-list (cons lrpt pl-list)
            pl-list (cons (setq lrpt+ (polar lrpt (/ pi 6.) (* ofd (/ 2. (sqrt 3))))) pl-list)
            pl-list (cons (polar lrpt+ (angle lrpt urpt) (distance lrpt urpt)) pl-list)
            pl-list (cons urpt pl-list)
            pl-list (cons (setq urpt+ (polar urpt (* pi 0.5) ofd)) pl-list)
            pl-list (cons (polar urpt+ (angle urpt ulpt) (distance urpt ulpt)) pl-list)
            pl-list (cons ulpt pl-list)
            pl-list (cons (setq ulpt+ (polar ulpt (+ (/ pi 6.) pi) (* ofd (/ 2. (sqrt 3))))) pl-list)
            pl-list (cons (setq llpt- (polar ulpt+ (angle ulpt llpt) (distance ulpt llpt))) pl-list)
          ; (setq pl-list nil)
      (setvar 'CLAYER lay)
      (entmake
        (append
          (list '(0 . "LWPOLYLINE")
                '(100 . "AcDbEntity")
                '(100 . "AcDbPolyline")
                (cons 90 (length pl-list))
                '(70 . 1)
          (mapcar '(lambda (pt) (cons 10 pt)) pl-list)
      (setq lpt_txt (list (car llpt-) (cadr llpt))
            upt_txt (list (car llpt-) (cadr ulpt))
            dist    (/ (- (distance lpt_txt upt_txt) 285.) 2.)
      (command "_.layer" "_M" layn "")
      (mk_txt (polar lpt_txt (angle lpt_txt upt_txt) dist) txt1)
      (mk_txt (polar lpt_txt (angle lpt_txt upt_txt) (+ dist 185.)) txt2)
      (command "_.layer" "_M" "Hidden" "_C" 8 "" "_L" "Hidden" "" "")
      (entmod (subst (cons 8 "Hidden") (assoc 8 ent) ent))
  (*error* nil)
  (princ)
Hope this helps,
Henrique
Message 9 of 10
jyan2000
Hello Henrique ,
Thank you very much for your replay. I've attached some codes and DWG FILE ( 3d Solid object )  which is similar to what we are trying to do. Below is some of my respond;
  • expects only one 'lwpolyline' in WCS in the dwg-
-There will be only one closed Polyline at the beginning.
- New PLINE layer Will be layer 'xxx_#' , Original PLINE layer will change to " Hidden"
  • don't deals with the 'TXT_##' layer color (I could not find a relationship between the 'TXT_##' layer color color, and the 'TXT_##' layer color)
-TXT_##' layer is a new layer. could've same colors same as Type_##' layer color
-Text style is Romans.shx
Hidden linetype scale is 11.
(DEFUN C:3Point Align ( / wtxt1 e i x ss)
(command "-Style" "0-GBal" "SWISSLI.ttf" "" "" "" "N" "N" "")
(command "-layer" "m" "0-GBal" "")
(command "-layer" "s" "0-GBal" "")
(if (not align) (arxload "geom3d" T))
(SETQ SS1 (SSGET))
(SETQ PT1 (GETPOINT "\nPick 1st Source Point (0,0)")
PT2 (GETPOINT "\nPick 2nd Source Point (1,0)")
PT3 (GETPOINT "\nPick 3rd Source Point (0,1)")
D1 (LIST 0.0 0.0 0.0)
D2 (LIST 1.0 0.0 0.0)
D3 (LIST 0.0 1.0 0.0)
(ALIGN SS1 PT1 D1 PT2 D2 PT3 D3)
(command "explode" "all")
(setvar "peditaccept" 0)
(command ".pedit" "m" "all" "" "y" "j" "0" "")
(if (or (null ofd)
(setq ofd 74.)
(command "zoom" "e")
(command ".erase" "all" "r" "p" "r" "l" "")
(setvar "CMDECHO" 0)
(initget 1)
(entmake '((0 . "TEXT") (40 . 99) (1 . "TYPE - 01")(10 165.0 725.0 0.0)))
(entmake '((0 . "TEXT") (40 . 99) (1 . "Pcs - 01")(10 165.0 560.0 0.0)))
(setvar "clayer" "0")
(setvar "celtype" "bylayer")
(setvar "CECOLOR" "bylayer")
(setvar "CELWEIGHT" -1)
(princ)
Message 10 of 10
hmsilva
You're welcome,  Victor!
As I had already said in my previous post, I'm with a large workload, and I don't have much free time...
Now it's time for you try to put the code together.
Henrique
