ERASE LAST OBJECT
ERASE LAST OBJECT
rolisonfelipe
Message 1 of 10
ERASE LAST OBJECT
rolisonfelipe
(DEFUN SELECT ()
(command "_UNDO" "_BEGIN")
(if SALVA (SALVA (list "OSMODE" "CLAYER" "TEXTSTYLE")))
(setvar "OSMODE" 0)
(setq VVBL "STANDARD-AMBIENTE")
(VERIFICA-VVBL VVBL)
(setq FLAGX T)
(setq ENTS1 (ENTSEL "\n>>Selecione um poligono <ENTER=Fim>: "));;; SELECT THE POLIGON
(while FLAGX
(setq FLAGA T)
(while FLAGA
(if (NOT ENTS1) (progn (setq FLAGA nil)(setq FLAGX nil)))
(if FLAGX
(progn
(setq ENT1 (car ENTS1))
(setq PT1 (cadr ENTS1))
(setq LL1 (ENTGET ENT1)), SELETIONS
(setq TIPO (cdr (ASSOC 0 LL1)))
(if (OR (= TIPO "LWPOLYLINE")(= TIPO "REGION"));;; OBJECT CALL
(setq FLAGA nil)
(ALERT "OBJETO SELECIONADO NÃO É UM POLIGONO!") ))))
(if FLAGX (progn (command "_AREA" "_O" ENT1);;;CALL AREA
(setq VVAREA (strcat (rtos (GETVAR "AREA") 2 2) "m²"));;; ÁREA DESIGNER
(setq VCENT (EXECUTAR-CENTROID ENT1));;;;; CALL CENTER AREA
(command "_INSERT" VVBL VCENT ESCALA "" "" VVAREA NIVEPR (NTH (ATOI NLA) LLAREA2) (NTH (ATOI NLR) LLREVE2) ) ;;; INSERT BLOCK NAME ROM/AREA/
(setq ENTS1 (ENTSEL "\n>>Selecione um poligono <ENTER=Fim>: ")))));;;; NEXT AREA, I LIKE IN THIS POINT ERASE LAST OBJECT " ENTS1",, IT IS OBJECT LIMIT ONLY FOR CALL..
(if RESTAURA (RESTAURA))
(command "_UNDO" "_END"))
Replies (9)
Message 2 of 10
ВeekeeCZ
Using just
(entdel ents1)
is not working for you ?
Message 3 of 10
rolisonfelipe
(entdel ENTS1)
ERRO : bad argument type: lentityp (<Entity name: -25df80> (1615.0 654.89
0.0))
Message 4 of 10
ВeekeeCZ
ohhh, it should be just ENT1
Message 5 of 10
hak_vz
(entdel (entlast))
;or in your case  there is an error
;replace with
(setq ENTS1 (CAR(ENTSEL "\n>>Selecione um poligono <ENTER=Fim>: ")))
Miljenko Hatlak
Message 6 of 10
rolisonfelipe
(DEFUN SELECT (); ORIGINAL LSP
(setvar "OSMODE" 0)
(setq FLAGX T)
(while FLAGX
(setq FLAGA T)
(while FLAGA
(if FLAGX
(progn
(setq FLAGA nil)
(command "_INSERT" VVBL VCENT ESCALA "" "" VVAREA NIVEPR (NTH (ATOI NLA) LLAREA2) (NTH (ATOI NLR) LLREVE2))
(setvar "OSMODE" 0)
(setq FLAGX T)
(while FLAGX
(setq FLAGA T)
(while FLAGA
(if FLAGX
(progn
(setq FLAGA nil)
(entdel (entlast))) ;;;AT THIS POINT THE SELECTED "ETS1" OBJECT IS DELETED. BUT DOES NOT ALLOW THE INFORMATION TO BE CAPTURED TO TRANSMIT TO THE BLOCK.
(entdel (entlast))) ;;;;IF I ADD AT THIS POINT HE READ THE SELECTED OBJECT INSERT THE BLOCK, KEEP THE SELECTED OBJECT AND NEXT THE BLOCK NEXT.
WITH THAT FRAGMENT OF THE ERROR
Message 7 of 10
rolisonfelipe
I NEED THE YELLOW LINE TO BE DELETED AFTER THE SELECTION AND THEN THE BLOCK IS INSERTED.
(DEFUN SELECT ()
(setvar "OSMODE" 0)
(setq FLAGX T)
(while FLAGX
(setq FLAGA T)
(while FLAGA
(if FLAGX
(progn
(setq FLAGA nil)
(ALERT "OBJETO SELECIONADO NÃO É UM POLIGONO!") )(entdel (entlast)))))
Message 8 of 10
hak_vz
@rolisonfelipeYou can not access property of an deleted object. So take object area, store it to same variable and than erase it.
Miljenko Hatlak
Message 9 of 10
rolisonfelipe
IN THE RIGHT PLACE, THIS FRAGMENT DID EXACTLY WHAT IT NEEDED. I LEARNED ONE MORE VARIABLE "entdel"
THANK YOU
Message 10 of 10
rolisonfelipe
I have not yet taken the way of storing variable, but I try to follow the logic without understanding what is being proposed, liguage opener like this allow me to adapt and create new functions, but when using vl-xxxx is much more compact and complex any modification, because there is no room for maneuver is all more specific, but thanks for inluminating my walk of knowledge
Solved: Copy attribute - Autodesk Community - AutoCAD this lsp  is one variation
