erase all text with exception of color 'bylayer'
larsr2866
larsr2866
I'm trying to make a lisp to erase all text wich color isn't bylayer, but it doesn't seem to work.
Can someone help me with this?
Thanks in advance!
(command
"_.erase"
(ssget "_X" '((0 . "TEXT,MTEXT") (-4 . "<not")(cons 62. "256")(-4 . "not>")))
(if (> (getvar 'cmdactive) 0)
(command "")
Kent1Cooper
A couple of problems* -- try this in place of that one line:
(ssget "_X" '((0 . "*TEXT") (-4 . "<NOT") (62 . 256) (-4 . "NOT>")))
And I would simplify the completion of the Erase command -- no need to end the (command) function it's in and then check whether it's still running to give it a concluding Enter "":
(command
  "_.erase"
* Problems:  In a "quoted" list [the apostrophe], you can't include a (cons) function that requires evaluation.  If used in a non-quoted (list) function where that would be allowed, the period after the 62 can't be there, and the 256 can't be in quotes.
Kent Cooper, AIA
larsr2866
Thanks! That worked perfect! 🙂
Moshe-A
@larsr2866
 or this,  selects all objects that are not BYLAYER
(setq ss (ssget "_x" '((-4 . "<>") (62 . 255))))
Moshe
Kent1Cooper
@Moshe-A wrote:
... selects all objects that are not BYLAYER
True, if with 256.
Kent Cooper, AIA
