Entmake LWPOLYLINE using 2 points
rpajounia
Message 1 of 11
rpajounia
Is there a way i can make a rectangle using entmake. I can provide bottom left corner points and top right corner points
Replies (10)
Message 2 of 11
hak_vz
(defun _rect (p1 p2 / lt point2d x1 y1 x2 y2 pts)
	(defun lt (pt) (trans pt 1 0))
	(defun point2d (pt) (list (car pt) (cadr pt)))
        ;(command "_.ucs" "w")
	(setq
		x1 (apply 'min (mapcar 'car (list p1 p2)))
		y1 (apply 'min (mapcar 'cadr (list p1 p2)))
		x2 (apply 'max (mapcar 'car (list p1 p2)))
		y2 (apply 'max (mapcar 'cadr (list p1 p2)))
	    pts (mapcar 'point2d(mapcar 'lt (list (list x1 y1) (list x2 y1) (list x2 y2) (list x1 y2))))
	(cond
		((and pts)
			(entmake
				(apply 'append
					(cons
					  (list
						'(0 . "LWPOLYLINE")
						'(100 . "AcDbEntity")
						'(100 . "AcDbPolyline")
						'(410 . "Model")
						'(8 . "0")
						'(38 . 0)
						'(62 . 256)
						'(67 . 0)
						(cons 90 (length pts))
						'(70 . 1)
					  (mapcar 'list (mapcar '(lambda (a) (cons 10 a)) pts))
	(princ)
Usage:
(setq p1 '(200 200) p2 '(100 100))
(_rect p1 p2)
This will create rectangle in current UCS starting from first point in lower left corner and drawn  in counter-clockwise direction as a closed polyline.
If you work in World UCS remove ; in front (command "_.ucs" "w") in above code
I hope you know how to add it to your code
Miljenko Hatlak
Message 3 of 11
ronjonp
@hak_vz
FWIW, I had to put the closed flag 70 after code 90 for this to work.
				      '(70 . 1)
Message 4 of 11
hak_vz
@ronjonp wrote:
@hak_vz
				      '(70 . 1)
Hi @ronjonp
I've written this code without testing from my second computer that don't have Autocad installed. After testing I have to admit your correction is needed for closing poyline. I have made this changes to code above.
Thanks!
Miljenko Hatlak
Message 5 of 11
Kent1Cooper
@ronjonp wrote:
... the closed flag 70 after code 90 for this to work.
				      '(70 . 1)
Or '(70 . 129) if a non-continuous linetype is involved and you want linetype generation enabled.
Kent Cooper, AIA
Message 6 of 11
ronjonp
You could also check the PLINEGEN setting:
(cons 70
      (if (= 0 (getvar 'plinegen))
	1
	129
Message 7 of 11
Kent1Cooper
Why, if I may ask, do you want to do it with (entmake)?  You may have a good reason, but this is a good example of how very complex that can be in comparison with just using a command that takes care of all that complexity for you [in less than 1/24 as many code characters ignoring spaces]:
(command "_.rectang" p1 p2)
Kent Cooper, AIA
Message 8 of 11
rpajounia
entmake returns the entity id of the new created poly line 🙂
Message 9 of 11
ronjonp
entmakeX returns the ename ... but really you could use a command route if necessary and call (entlast) after it's created.
Message 10 of 11
rpajounia
*edited* nvm had set and not setq
Message 11 of 11
ronjonp
Change entmake to entmakeX. Or set the the entmake to 'e' and call this: (setq e (cdr (assoc 0 (entget e))))
