ENTMAKE crashes Autocad after call to VBA
caddhelp
caddhelp
I have Fatal error on newer versions of Autocad
Lisp  function is calling VBA and then entmake crashes Autocad
The first lisp is calling VBA MsgBox. You will need to save dvb vile at c:\Temp\msgbox.dvb
The second(NewLine) is crashing on entmake
(defun MsgBox ( StringParam / retList ret )
	(setq retList '("None" "OK" "CANCEL" "ABORT" "RETRY" "IGNORE" "YES" "NO"))
	(vl-vbaload C:\\Temp\\msbbox.dvb"))
	(setq ret(atoi(getstring(command "-VBARUN" "vbMsgBox" StringParam))))
	(nth ret retList)
(defun NewLine()
  (msgbox "Create a New Line, 64, Title")
  (entmake (list'(0 . "LINE")(cons 10 (getpoint))(cons 11 (getpoint))))
This is a VBA code. Create a new VBA project and save it at c:\Temp\msgbox.dvb
Sub vbMsgBox()
  Dim arrParam, ret
  Param1 = ThisDrawing.Utility.GetString(False)
  arrParam = Split(Param1, ",")
  ret = MsgBox(arrParam(0), CInt(arrParam(1)), arrParam(2))
  ThisDrawing.SendCommand ret & vbCr
End Sub
We cannot use C# or VB.net. Only Autodesk VBA or VisualLisp
Any ideas? Does it crash only my Civil3D?
Thanks.
_gile
What about using @Lee_Mac 's LM:popup?
;; Popup  -  Lee Mac
;; A wrapper for the WSH popup method to display a message box prompting the user.
;; ttl - [str] Text to be displayed in the pop-up title bar
;; msg - [str] Text content of the message box
;; bit - [int] Bit-coded integer indicating icon & button appearance
;; Returns: [int] Integer indicating the button pressed to exit
(defun LM:popup ( ttl msg bit / wsh rtn )
    (if (setq wsh (vlax-create-object "wscript.shell"))
        (progn
            (setq rtn (vl-catch-all-apply 'vlax-invoke-method (list wsh 'popup msg 0 ttl bit)))
            (vlax-release-object wsh)
            (if (not (vl-catch-all-error-p rtn)) rtn)
(defun NewLine()
  (LM:popup "Title" "Create a New Line" 64)
I would have two pieces of advice:
Avoid mixing programming environments (it is often much less simple than it seems)
Forget the AutoCAD VBA (personal opinion)
Gilles Chanteau
GileCAD
GitHub
hak_vz
Check this line
Change to
(vl-vbaload C:\\Temp\\msgbox.dvb"))
 Also, it is always better to check if all parameters for entmake are set
change to
(cond
	((and (setq a (getpoint))(setq b (getpoint)))
		(entmake (list '(0 . "LINE")(cons 10 a)(cons 11 b)))
Miljenko Hatlak
caddhelp
Thank you for the responses. I really appreciate the brainstorming!
MsgBox is just an example of using VBA. The real program is using huge Dialog with bunch of Combo Boxes and more.
The entmake here makes a single line is also a simplification. The real thing is creating a lot more, also using entmakex(hence the crush) to generate dictionaries.
Add open quote
(vl-vbaload "C:\\Temp\\msbbox.dvb"))
could be simpler
(entmake (list '(0 . "LINE")(cons 10 0 0 0)(cons 11 1 1 0)))
I did send the Autodesk Error report, but from my experience ;(
Keep digging!
Sea-Haven
Another msg box method.
(defun MsgBox (title buttons message time / return WshShell)
    (setq WshShell (vlax-create-object "WScript.Shell"))
    (setq return (vlax-invoke
            WshShell
            'Popup
            message
            time
            title
            (itoa buttons)
    (vlax-release-object WshShell)
    return
Another
(alert "this is a 2 line message \n2nd line")
caddhelp
The call to MsgBox is just an example of Lisp->VBA->Lisp technique.
Mixing programing have been done forever with different languages.
I think the problem here is something to do with ENTMAKE. It could've been rewritten in C# so now it actually opens object for writing while VBA32 is still in the memory.
