Entmake annotative texts with scales
Hi everyone, as said in title, i want to entmake texts with annotative scales (one depending on current scale and two preset) but i cant find the way. I tryed creating it and then making it annotative and giving it those extra scales, but the size of the text was changed depending on what scale i had activated (so i was changing it to 1:100 every time i did that and worked that way).
Im entmaking a block with a polygon and attributes to export it to ArcGIS, and creating another with "COMMAND "_block"" including the polygon and all those texts (measures and names) cause they are going to be printed (pdf or paper, i dont know yet)
tyler.youngZKNVG
opazojonatan,
Try this:
txt is the single string you supply
sty is the text style
pos is the position of the mtext object
hgt is the height of the text based on a (getvar "CANNOSACLE") value where in my case i divide whatever the CANNOSCALE value is by 2
ang is the angle of the mtext in radians
jus is the justification a value of 1-9
(defun makemtext (txt sty pos hgt ang jus)
(entmakex
(list
(cons 0 "MTEXT")
(cons 100 "AcDbEntity")
(cons 100 "AcDbMText")
(cons 1 txt)
(cons 7 sty)
(cons 10 pos)
(cons 40 hgt)
(cons 41 0.0)
(cons 50 ang)
(cons 71 jus)
);end list
);end entmake
(command "_change" (entlast) "" "P" "Anno" "Y" "")
);end defun makemtext
Tyler Young
Thats what im doing now. I create the text in scale 1:1, that way it wont modify its size, and then use a (FOREACH i lst (COMMAND...)) where lst is a list of scale names to apply. But anyway im looking for a way to entmod those texts, because i build blocks with them and i cannot use (command "_change") with items inside blocks... Now im exploding the block, changing text scales then rebuilding the block with same name and attributes, it works well but i still want to know if its possible to do it with entmake/entmod...
Thanks!
