Entity Data Comparison
kpennell
kpennell
When I compare the data of the same entity, and do a comparison, I always get a 'nil' returned.
(setq before (entget (car (entsel)))); I pick an entity
(setq after (entget (car (entsel)))); I pick the exact same, unmodified entity
(= before after); this always returns 'nil'.
I'm studying the 'entget' data, and all the strings and numbers are identical.  Should it return to me as 'T'?
Weird.  Thanks.
kpennell
So I'm guessing, it has something to do with the name of the selection set, which gets recorded in the data, but not presented?
Kent1Cooper
The (=) function takes number or string arguments only [read about it in Help].  Use (equal) or (eq) instead.
Kent Cooper, AIA
rkmcswain
Since these functions can be hard to find in help these days, here are a couple of links.
= | equal
R.K. McSwain     | CADpanacea | on twitter
kpennell
I did as you suggested. I'm taking it, that 'equal' is true and forgiving than '=' or 'eq'.
Thanks for this.
devitg
I use to check same enty , the 5 code , it is the handle, handle is one and unique for each enty , or the OBJECTID .
(SETQ ENT-A (CAR(ENTSEL "/N PICK YOU ENTY")))
(SETQ ENT-B (THE-SAME-NOT ENT-A))
(DEFUN THE-SAME-NOT  (ENT-A
                      HANDLE-A
                      HANDLE-B
  (SETQ HANDLE-A (CDR (ASSOC 5 (ENTGET ENT-A))))
  (SETQ ENT-B (CAR (ENTSEL "/N PICK THE OTHER")))
  (SETQ HANDLE-B (CDR (ASSOC 5 (ENTGET ENT-B))))
  (IF (= HANDLE-B HANDLE-A)
    (PROGN
      (ALERT
        (STRCAT "\nYou did not understood what I ask for , try it again!")
      (THE-SAME-NOT ENT-A) ; RECURSIVE
  ENT-B
(SETQ ENT-B (NOT-THE-SAME ENT-A))
(DEFUN NOT-THE-SAME  (OBJ-A /
                      OBJ-A-ID OBJ-B OBJ-B-ID
(VL-LOAD-COM)
  (IF (= (TYPE OBJ-A) 'ENAME)
    (SETQ OBJ-A (VLAX-ENAME->VLA-OBJECT OBJ-A))
  (SETQ OBJ-A-ID (VLA-GET-OBJECTID OBJ-A))
  (SETQ ENT-B (CAR(ENTSEL "/N PICK THE OTHER")))
  (SETQ OBJ-B (VLAX-ENAME->VLA-OBJECT ENT-B))
  (SETQ OBJ-B-ID (VLA-GET-OBJECTID OBJ-B))
  (IF (= OBJ-A-ID OBJ-B-ID)
    (PROGN
      (ALERT
       (strcat "\nYou did not understood what I ask for , try it again!"  )
      (NOT-THE-SAME OBJ-A ); RECURSIVE
      ); PROGN
  ENT-B
