Enter key to repeat
Enter key to repeat
saitoib
Message 1 of 22
Enter key to repeat
saitoib
Hi all!
I want to make it so that when I ask for user input in a while iteration, if the value is the same as the last time, all I have to do is press Enter.
So, I came up with the following code.
However, I'm wondering if I can make it a bit smarter and more Lisp-like.
Please give me some advice.
(defun c:test1 (/ inp temp)
	(while (and
		(if (not inp)
			(progn
				(initget 7)
				(setq inp (getreal "\nEnter a real number :"))
			(progn
				(initget 6)
				(setq temp inp)
				(prompt "\nEnter a real number <")
				(princ inp)
				(setq inp (getreal "> :"))
				(if (not inp)
					(setq inp temp)
					(setq inp inp)
		(princ "\nInput Data = ")
		(princ inp)
		(princ)
Saitoib
Accepted solutions (3)
Replies (21)
Message 21 of 22
Sea-Haven
Your correct saved on the pc in the registery.
Message 22 of 22
john.uhden
@Kent1Cooper
As civils, we are often creating the building footprint from architect's plans, so we like to enter the distances in architectural format, verbatim.  I have also learned not to trust the PDF they send you in terms of tracing their linework.  So the published distances are gospel, as they would be to the builder.
John F. Uhden
