entdel to remove dictionary item?
DC-MWA
Message 1 of 12
DC-MWA
I have a strange item showing up randomly in some of our drawings.
I use
(cdr (assoc 3 (dictsearch (namedobjdict) "ACAD_DATALINK")))
this should show nil or show the datalinks in the drawing.
Randomly "MWA template" shows up. We have no clue how this is created. It's the name of our office template.
I've tried  (dictremove (namedobjdict) "MWA template")  to remove it, no luck.
I've seen posts that mention entdel.
Not sure how to do this?  I've tried:
(setq test (namedobjdict) "MWA template")
(entdel test)
no luck.
Replies (11)
Message 2 of 12
Something like ?
(setq ss (ssget ((0 . "XXXX") (2 . "XXXXX")));;Filter DXF code
      i 0)
(repeat (setq i (sslength ss))
 (entdel (ssname ss (setq i (1- i))))
Message 3 of 12
DC-MWA
Not sure how this would work with what I'm trying to achieve?
Message 4 of 12
Use Code DXF to filter what you want to delete then delete (entdel) the entire length of your selection. The code below deletes all circles of cyan color.
(defun c:SE (/ ss i) ;;command name
  (setq ss (ssget "_X" '((0 . "CIRCLE") (62 . 4)));;Filter DXF code
      i 0) ;;id
  (repeat (setq i (sslength ss));; repeat t length
    (entdel (ssname ss (setq i (1- i)))) ;; delete
  (princ)
Message 5 of 12
ronjonp
Try this .. you need to go one step deeper to get your "MWA template".
(and (setq e (cdr (assoc -1 (dictsearch (namedobjdict) "ACAD_DATALINK"))))
     (setq e (cdr (assoc -1 (dictsearch e "MWA template"))))
     (entdel e)
Message 6 of 12
DC-MWA
I tried it, not sure whats going on....
Command: (cdr (assoc 3 (dictsearch (namedobjdict) "ACAD_DATALINK")));;check for item
"MWA template"
Command:
(_> (setq e (cdr (assoc -1 (dictsearch e "MWA template"))))
(_> (entdel e)
(_> )
Command: (cdr (assoc 3 (dictsearch (namedobjdict) "ACAD_DATALINK")));;check again
"MWA template (1)"  ;;;now shows name(1) ???
Message 7 of 12
ronjonp
You must have a mess going on 🙂 .. see what this returns:
(mapcar	'print
	(vl-remove-if '(lambda (x) (/= 3 (car x))) (dictsearch (namedobjdict) "ACAD_DATALINK"))
Note that (assoc 3 above will only return the first occurrence within the acad_datalink dictionary .. there could be many entries in there.
Message 8 of 12
DC-MWA
Here's what came up:
(3 . "MWA template")
(3 . "MWA template (1)")
(3 . "MWA template (2)")
(3 . "MWA template (3)") ((3 . "MWA template") (3 . "MWA template (1)") (3 . "MWA template (2)") (3 . "MWA template (3)"))
Message 9 of 12
ronjonp
Yup looks like a mess 😛 .. this should clean it up assuming you don't want all those!
(defun c:foo (/ a b)
  ;; RJP » 2020-01-17
  ;; Delete MWA* datalinks
  (foreach e (setq a (dictsearch (namedobjdict) "ACAD_DATALINK"))
    (if	(and (= 3 (car e)) (wcmatch (strcase (setq b (cdr e))) "MWA*"))
      (progn (entdel (cdadr (member e a))) (print (strcat b " deleted...")))
  (princ)
Message 10 of 12
DC-MWA
I was able to incorporate this into my routine. Works perfectly.
Thank you.
Any idea what is creating these?  Our cad template (drawings) is named "MWA template", but these do not show up in every project produced using the template drawings. It's very random.
Any ideas?
Message 11 of 12
ronjonp
Thank you.
Any ideas?
Glad to help out. 🍻 I'm not sure what is causing your datalink problems.
Message 12 of 12
DC-MWA
Thank you.
