Enlarge Dialog box in autocad/autolisp
How to expand or enlarge or resize a dialog box a bigger in autocad or autolisp.
Moshe-A
@Anonymous  hi,
On what dialog specially you are talking? is it AutoCAD Standard? is it a custom command you have or you design?
in fundamental if you are talking about dcl as a user you can not enlarge the dialog after the author designed it cause it is totally static.
moshe
Thanks for your reply,
Yes, it is custom dialog from another plugin dll. As  you said that is correct we cannot change the size, but I am interested to know is there any general setting in AutoCAD options to enlarge dialog box.
scot-65
Nope.
Change screen resolution instead.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Sea-Haven
I remember reading in the paper copy like R14 that font size is fixed, just a way out there suggetsion, if you could reset the windows font size, dialog may go bigger but bit problematic, VBA dialogue may have a size factor if writing your own. Opendcl is mentioned but writing your own.
https://pureinfotech.com/change-display-settings-make-icons-text-bigger-windows-10/
