elevation
elevation
hossein_abdollahiELUZP
elevation
Regarding the AutoCAD version, it is 2020. However, when I load the LSP file and set the elevation,
it does not automatically assign the elevation numbers.
Instead, a window titled "Enter Attributes" appears, requiring manual input of the numbers after executing the elevation drawing command.
I'd appreciate to help me find the solution.
Kent1Cooper
@hossein_abdollahiELUZP wrote:
.... when I load the LSP file ....
What LSP file?
Kent Cooper, AIA
rgrainer
post the lsp file and a sample drawing showing what happens currently and what you expect the final result to look like. No one can help you based on a screen grab.
The LSP files have been attached, along with a sample CAD file.
The issue at hand is as follows: When I load the LSP file and execute the "Elset" command to set the elevation based on a specific point, the problem arises when I attempt to use the "TEGER" command to input the elevation number at a different point. Instead of functioning correctly, the "Enter Attribute" window pops up. It is worth noting that these operations work properly on my colleague's system.
Please review the file, as all the elevations you see were generated using my colleague's system.
Thank you.
Kent1Cooper
Do you have your ATTDIA System Variable set to 1?  Read about it, and set it to 0 [zero], which I assume is your colleague's setting.
Kent Cooper, AIA
I have tested it, and it functions correctly.
I sincerely appreciate your assistance.
Best Regards
