Edit object then add strike-through dimention.
ramoneramone
ramoneramone
Hi dear.
First edit object, then add strike-through old text of dimension, conclude new text and old text.
(defun c:strikedim ()
(setq ent_name (car(entsel "select dim")))
(setq ss (entget ent_name))
(setq text (cdr (assoc 42 ss)))
(setq text_old (strcat "\\K" (rtos text)))
(setq text_new (strcat "<>" " " text_old))
(command "dimedit" "e" text_new ent_name "")
EnM4st3r
like this?
(defun c:strikedim (/ correctent-p textent text dimdata dimdata-1 dimdata-13 dimdata-14)
  (defun correctent-p (ent /)
    (if ent
      (and  (= (cdr (assoc 0 (entget (car ent)))) "MTEXT")
            (if (= (type (car (nth 3 ent))) 'ENAME)
              (= (cdr (assoc 0 (entget (car (nth 3 ent))))) "DIMENSION")
              nil
      nil
  (while (not (correctent-p textent))
    (setq textent (nentsel "\nSelect the Dimension text: "))
  (setq text (vla-get-textstring (vlax-ename->vla-object (car textent)))
        dimdata (entget (car (nth 3 textent))) ;save original dimension data
        dimdata-13 (append '(13) (getpoint "\nFirst Dimension Point: "))
        dimdata-14 (append '(14) (getpoint "\nSecond Dimension Point: "))
        dimdata-1 (cons 1 (strcat "<> {\\K" text "}"))
        dimdata (subst dimdata-13 (assoc 13 dimdata) dimdata) ; replace with new data
        dimdata (subst dimdata-14 (assoc 14 dimdata) dimdata)
        dimdata (subst dimdata-1 (assoc 1 dimdata) dimdata)
  (entmod dimdata)
  (princ)
  (princ)
ramoneramone
It is almost exactly as I imagined.
Would it be possible to make the dimensions change by drag and drop instead of using the get point function?
EnM4st3r
i dont know how you would implement that into one lisp,
but I can just remove those steps so it literally just strikes the dimension:
(defun c:strikedim (/ correctent-p textent text dimdata dimdata-1)
    (if ent
              nil
      nil
        dimdata-1 (cons 1 (strcat "<> {\\K" text "}")) ;set strike-text
        dimdata (subst dimdata-1 (assoc 1 dimdata) dimdata) ;apply strike-text
  (entmod dimdata)
  (princ)
ramoneramone
Thanks😀
