Edit Block Attributes
T2oog
Message 1 of 8
T2oog
I am new to the forum and to AutoLISP.  I have looked at several posts on this topic but they look more complicated than what I want, and I get confused.   If I can get some good detailed answers, it might help me begin to understand LISP better.
I have a block named, "1REV1".
It has the following tags:
MICROFILM
NO
DATE
1
BY
CHK'D
ENG
APP
To keep this simple for now, I only want to get the block (1REV1) and change the existing DATE attribute value (whether empty or not) to one defined in the LISP.
Thank You,
New User
Replies (7)
Message 2 of 8
paullimapa
did you find this thread in your search:
Solved: EDIT ATTRIBUTE VALUE WITH LISP - Autodesk Community - AutoCAD
Paul Li
IT Specialist
@The Office
Message 3 of 8
ВeekeeCZ
If there is only one of its kind in the drawing, not dynamic, here is your magic line. Tag is case-sensitive.
(setpropertyvalue (ssname (ssget "X" '((0 . "INSERT") (2 . "1REV1"))) 0) "DATE" one-defined-in-the-LISP)
Message 4 of 8
Sea-Haven
Try this can replace newdate with say a get string for date or get current date from ACAD.
(defun wow (bname tagname newdate / ss1 x)
(setq ss1 (ssget "x"  (list (cons 0 "INSERT") (cons 2 bname)(cons 410 "model"))))
(repeat (setq x (sslength ss1))
   (foreach att (vlax-invoke (vlax-ename->vla-object (ssname SS1 (setq x (1- x) ))) 'getattributes)
        (if (= tagname (strcase (vla-get-tagstring att)))
        (vla-put-textstring att newdate)
(princ)
(wow "1REV1" "DATE" "newdate")
Message 5 of 8
T2oog
It looks like a great example. I am just beginning and don't understand. I am ordering a book.
Thanks though
Message 6 of 8
T2oog
I will have a closer look at this one. Like my comment above, I have not yet put things together.
Message 7 of 8
T2oog
This one runs when I open the drawing. It changes the "newdate" to whatever I enter in its place, such as "9/27/22". It does what I asked for, although maybe I would rater it run when I type "wow". I am new and have ordered a book with hopes of learning. Maybe other beginners will find this post helpful.
Thank You!
Message 8 of 8
Sea-Haven
Books are available on KINDLE very cheap, also Afralisp has a series of tutorials worth looking at.
Just add the lines like (setq date (getstring "\nEnter date xx/xx/xxxx ")) before the ssget and hard code the other variables bname and tagname.
Remove the passing variables at start (defun wow  / date ss1 x) ; note the localization of variables.
Good to see trying to learn you will get more help having a go rather than I want.
