Edit attribute within nested block script
leeUT3Y6
leeUT3Y6
I found a script by Lee Mac on the forum for changing a nested block attribute with a lisp.
I'm trying to change it so instead of predefined set of values, the script will ask you for a block, and then ask you for the value you would like set in its nested attribute.
I'm new to LISP and no luck so far.
The original scrip and the modified are attached.
Please help
BR
Lee
ВeekeeCZ
All you need is this to change in original code:
  (initget 1)
  (setq int (getint "\nEnter an integer: "))
  (setq data (list (cons "MYATT" (itoa int))))
;;; '( ;;; ("NUM" . "1") ;;; ("ID" . "01/12/2011") ;;; ("ADRESS" . "FOR REVIEW") ;;; ("CODE" . "MAL") ;;; ("ROOMNR" . "01/12/2011") ;;; ) ;;; )
leeUT3Y6
Thanks! It Works!
I prefer it first to ask for the block, and then for the attribute.
The code is attated.
ВeekeeCZ
You got it, cool!
