Dynamic Block - Changing the visability state in a lisp
Message 1 of 15
Good Afternoon:
I am looking for a lisp that will allow me to select a dynamic block and change the visibility state.
I have found a bunch that do it while inserting the block, but not if the block is already on the drawing.
Any help would be greatly appreciated
Greg
Replies (14)
Message 2 of 15
ВeekeeCZ
hi, look HERE on Lee's page, where is bunch of subroutines working with dynamic blocks.
Message 3 of 15
wispoxy
(defun c:YOURCOMMANDHERE ( / blk idx obj sel vis )
(setq blk "DYNAMICBLOCKNAMEHERE"
vis "VISIBILITYSTATENAMEHERE"
(if (setq sel (ssget "_X" (list '(0 . "INSERT") (cons 2 (strcat "`*U*," blk)) '(410 . "~Model"))))
(repeat (setq idx (sslength sel))
(if (= (strcase blk) (strcase (LM:blockname (setq obj (vlax-ename->vla-object (ssname sel (setq idx (1- idx))))))))
(LM:SetVisibilityState obj vis)
(princ)
(defun LM:blockname ( obj )
(if (vlax-property-available-p obj 'effectivename)
(defun LM:blockname ( obj ) (vla-get-effectivename obj))
(defun LM:blockname ( obj ) (vla-get-name obj))
(LM:blockname obj)
(defun LM:SetVisibilityState ( blk val / vis )
(if
(and
(setq vis (LM:getvisibilityparametername blk))
(member (strcase val) (mapcar 'strcase (LM:getdynpropallowedvalues blk vis)))
(LM:setdynpropvalue blk vis val)
(defun LM:setdynpropvalue ( blk prp val )
(setq prp (strcase prp))
(vl-some
'(lambda ( x )
(if (= prp (strcase (vla-get-propertyname x)))
(progn
(vla-put-value x (vlax-make-variant val (vlax-variant-type (vla-get-value x))))
(cond (val) (t))
(vlax-invoke blk 'getdynamicblockproperties)
(defun LM:getdynpropallowedvalues ( blk prp )
(vl-some '(lambda ( x ) (if (= prp (strcase (vla-get-propertyname x))) (vlax-get x 'allowedvalues)))
(defun LM:getvisibilityparametername ( blk / vis )
(if
(and
(vlax-property-available-p blk 'effectivename)
(setq blk
(vla-item
(vla-get-blocks (vla-get-document blk))
(vla-get-effectivename blk)
(= :vlax-true (vla-get-isdynamicblock blk))
(= :vlax-true (vla-get-hasextensiondictionary blk))
(setq vis
(vl-some
'(lambda ( pair )
(if
(and
(= 360 (car pair))
(= "BLOCKVISIBILITYPARAMETER" (cdr (assoc 0 (entget (cdr pair)))))
(cdr pair)
(dictsearch
(vlax-vla-object->ename (vla-getextensiondictionary blk))
"ACAD_ENHANCEDBLOCK"
(cdr (assoc 301 (entget vis)))
(vl-load-com) (princ)
Message 4 of 15
wispoxy
Fill in the three sections:
YOURCOMMANDHERE <------- The command
DYNAMICBLOCKNAMEHERE <------- The block name with visibility states
VISIBILITYSTATENAMEHERE <------- The visibility state you want it to change to
Someone laid out the code for me, when I find out who it was I'll credit them.
Message 5 of 15
Good Morning and thank you for the reply
This is almost there
I need to be able to select the block, not do a generic blockname batch
Unless i am not seeing this correctly
Happy Friday
Message 6 of 15
wispoxy
That makes no sense, it selects a specific block, not a generic one.
Message 7 of 15
Hello and thank you for the follow up
Maybe i am not being clear, or i am misreading the code
If i understand it correctly - it is asking me to put in a blockname,  so if i have 100 blocks of the same name, it will change the visibility state of all 100
blocks, not the ones I am specific selecting
am i wrong . ?   thanks for your help
Message 8 of 15
m_badran
Select blocks which you need and change visibility statement from properties.
Message 9 of 15
wispoxy
Yes, it will change them all if they have the same name. That LISP template you're looking at I'm currently using.
Message 10 of 15
Thanks for the follow up
I was looking to find one that enables me to pick them, (with a crossing window) and change.
I may have 90 plus of a particular block on a drawing and only want to change the visibility state of 30 or so
Message 11 of 15
wispoxy
Now that sounds outside the LISP category. Software hard coding
Message 12 of 15
steve_carson
Like mostafabadran said, simply select the blocks you want to change and change the visibility state through the Properties palette (Select blocks, right click, select properties).
No lisp needed.
Message 13 of 15
Hi Andrew
Im trying to put a lisp program together to do the same change of dynamic block visibility but cant seem to get your code to work.
Sorry if these are newbie questions but i am very new to LISP (though not other languages)
Ive managed to write my own code to change all the atributes in dynamic blocks (using yours and LeeMac's examples as tutorials thanks) but im really struggling to get the Visibility change to work, even using LeeMacs libraries as functions.
So;
1 - Is the DYNAMICBLOCKNAMEHERE the string that shows up in the /Properties/Misc/Name field withthe block selected?
2 - Is the VISIBILITYSTATENAMEHERE one of the selectable strings that shows up in the /Properties/Custom/Visibility1 field with the block selected?
Thanks for your help so far 🙂
Mike
Message 14 of 15
melanie.mKWEBN
Not sure what i am doing wrong here ... i know this has worked for me in the past for other dynamic blocks
I've added the name of the block and the name if the visibility state i want (example below - not the whole code)
load the app
run the command ... and nothing the block wont change - i need to run this on over 100 drawings to update
(defun c:VISSTATE ( / blk idx obj sel vis )
(setq blk "DRAWING_ISSUE_STAMP"
vis "CONSTRUCTION ISSUE"
Message 15 of 15
Sea-Haven
Can have multiple visibilities in a block. Double check Lee-Mac's  code if that is what your using.
(LM:SetVisibilityState blk ans)
