Dynamic Block - Block Properties Table setting question
Hi all, I've been using a function from Mark Douglas from long ago with a few tweaks to modify dynamic block properties immediately after insertion -it works well for me with one exception: Block Property Tables. Now ya'll Know that Block Property Tables are different than lookup tables - those get processed quickly. However, when one of my blocks has a Block Property Table, modifying the settings just churns and churns for about 50x the time it rakes to run the program on any other set of properties.
I can tell that block property tables are safearrays (or that's what they seem to be to me). Somehow the code I use can change them but it is much slower than any other dynamic property. And more interestingly, I tried subbing in Lee Mac's LM:setdynpropvalue function instead of Mark Douglass' and with a little rewriting it works, but it actually seems a little slower yet.
Any Ideas why?
Here's a link to Lee's functions: http://www.lee-mac.com/dynamicblockfunctions.html
and here is the good old Mark Douglass code I have been using...
;_____________________________________________________________________________________________________________|
; Function for modifying dynamic blocks by: Mark Douglas (http://mdouglas.blogs.com/in_the_dynamic_interface/dynamic_blocks/page/2/)
; Tweeks by RapidCAD 2011
; Modifies Prop values within the ModifyDynBlk function
(defun setPropValue (oProps sProp Val / i oSBReferenceProperty sPName iFound)
(setq i (vlax-safearray-get-l-bound oProps 1))
(setq iFound 0)
(while (and (<= i (vlax-safearray-get-u-bound oProps 1)) (= iFound 0))
(setq oSBReferenceProperty (vlax-safearray-get-element oProps i))
(setq sPName (vla-get-PropertyName oSBReferenceProperty))
(if (= (strcase sPName) sProp);strcasex
(progn
(princ (vlax-variant-value (vla-get-value oSBReferenceProperty)))
(vla-put-value oSBReferenceProperty
(vlax-make-variant Val
(vlax-variant-type (vla-get-value oSBReferenceProperty))
(setq iFound 1)
(setq i (1+ i))
(princ)
; Main function for modifying dynamic blocks by: Mark Douglas (http://mdouglas.blogs.com/in_the_dynamic_interface/dynamic_blocks/page/2/)
; this needs to be fed a two item list (but not a dotted pair) comprised of the dynamic block parameter
; followed by the desired value for that parameter.
; Called by every POI program after TPINSERT and after (SETQ ss (SSGET "L")) by embedment in (loopprops)
(defun ModifyDynBlk ( lstProp / index cnt oBkRef oProps i j oSBReferenceProperty e)
(vl-load-com)
(setq index 0
cnt (sslength ss)
(while (< index cnt)
(setq e (ssname ss index))
(setq oBkRef (vlax-ename->vla-object e))
(setq oProps (vlax-variant-value (vla-GetDynamicBlockProperties oBkRef)))
(while (<= i (vlax-safearray-get-u-bound oProps 1))
(setq i (1+ i))
(setq j 0)
(while (< j (length lstProp))
(setq sProp (strcase (nth j lstProp)));strcasex
(setPropValue oProps sProp (nth (+ 1 j) lstProp));(LM:setdynpropvalue oBkRef (vla-get-PropertyName oSBReferenceProperty) (nth (+ 1 j) lstProp))
(setq j (+ 2 j))
(setq index (1+ index))
(princ)
; Main Function to loop through dynamic block properties - must point to exact known property names and push
; correct values in the correct type of value (integer, real, string). Must be fed dbpl (a list of lists of
; block properties followed by their values (list (list "typ_width_bf" "28\"")(list "geo_nominal_width" "28")))
(defun loopprops (/ lcnt llen dbp)
(setq lcnt 0)
(setq llen (length dbpl))
(while (< lcnt llen)
(setq dbp (nth lcnt dbpl))
(ModifyDynBlk dbp)
(if (= lcnt llen)
(ModifyDynBlk dbp)
(setq lcnt (+ lcnt 1))
(princ))
Any help greatly appreciated.
