I beleive this should be all on one line
{color:#ff0000}"" ; non-default number or other option if desired, with followup line(s) if necessary{color}
I like this lisp file , but how can I set the version to R12?
Craig
> {quote:title=drschonf wrote:}{quote}Thank you all!!!. This does the job.
> I'm now using this lisp:
> > (defun c:dxo ()
> > (command "cmdecho" 0)
> > (command "_.dxfout"
> > (getfiled "DXF File:" (getvar"dwgprefix") "dxf" 1)
> > "_Objects" (ssget)
> > "" ; completes selection
> > if necessary
> > ); end command
> > (command "cmdecho" 1)
> Question, after i used the command i get this error message (the lisp works!!!)
> > Command: DXO
> > Select objects: 1 found
> > Select objects: ; error: bad argument value: AutoCAD command: #@0000000028c5d610 IF>
> Is there a possibility to get ride of that message. I used 'cmdecho 0', but is still there.
> Daniel
Craig
