Visual LISP, AutoLISP and General Customization
DXFout customization
1 REPLY 1
dndee
231 Views, 1 Reply
I need to save only the basic dxf geometry information, not all the extra information that is saved with the file. Can this output be modified?
If I dxf out a circle, I need only to have a few lines of code that describe the circle, not hundreds of lines of extra code.
Thanks.
1 REPLY 1
in reply to: dndee
No, but you can write your own file.
(defun mf ( / )
(setq file (open "cicle.txt" "w"))
(princ (strcat "circle info\n") file)
(close file)
Forma Design Contest
