Dxf code to identify types of surfaces.
carlos_m_gil_p
carlos_m_gil_p
Hello boys how are you.
With what code dxf can I identify if an entity is a surface (loft), surface (network) or surface (Nurbs)
What I want is.
Select a surface with entsel.
And tell me what kind of surface it is.
But with DXF codes, not VL
Excuse my English, I only speak Spanish.
Thanks for the help.
AutoCAD 2026
Visual Studio Code 1.99.3
AutoCAD AutoLISP Extension 1.6.3
Windows 10 (64 bits)
cadffm
look into the dxf definition of you object:
(entget(car(entsel)))
Befehl: (assoc 0 (entget (car(entsel))))
Objekt wählen: (0 . "LOFTEDSURFACE")
Objekt wählen: (0 . "NURBSURFACE")
Sebastian
carlos_m_gil_p
@cadffm Hello how are you.
Thanks for answering.
Normally I do it like that.
But if you notice, the code of the surface (loft) and the surface (network) are the same.
And I do not know how I can identify which is which.
Thank you.
AutoCAD 2026
cadffm
If you compare group-0 you will see that is not clear enough for Loft and Network Surface
command: (assoc 0 (entget (car(entsel))))
(0 . "NURBSURFACE")
So  compare the xdata (Groupcode -3) of the objects: (entget (car(entsel)) '("*"))
(-3 ("ACAD_STEPID" (1071 . 5)))
(0 . "NURBSURFACE")
(-3 ("ACAD_SURFACE_XFORM" (1011 0.0 0.0 0.0) (1011 1.0 0.0 0.0) (1011 0.0 1.0 0.0) (1011 0.0 0.0 1.0)))
(-3 ("ACAD" (1000 . "AcDbLoftSurfaceType") (1070 . 2)) ("ACAD_STEPID" (1071 . 4)) ("ACAD_SURFACE_XFORM" (1011 0.0 0.0 0.0) (1011 1.0 0.0 0.0) (1011 0.0 1.0 0.0) (1011 0.0 0.0 1.0)))
!? one step further, we have a difference between Loft and Network Surface now.
Sebastian
doaiena
I know you said "not VL", but it is actually the easiest way.
(vla-get-surfacetype (vlax-ename->vla-object (car (entsel))))
This is the output for the three surfaces in your file:
- "Loft with cross sections only"
- "NURBS"
- "Network"
Is there any particular reason you don't want to use VL?
_gile
Simple, without VL, you can try :
(getpropertyvalue (car (entsel)) "SurfaceTypeName")
Gilles Chanteau
GileCAD
GitHub
carlos_m_gil_p
Hello @_gile
Thank you very much for your solution.
It's the best I've learned.
With this, it solves more than one problem I have.
Thank you very much everyone for your collaboration, too.
AutoCAD 2026
