Drawing list lisp
Drawing list lisp
mruPRQUJ
Message 1 of 12
Drawing list lisp
mruPRQUJ
Drawing list lisp
Hi, I wonder if one drawing list lisp can be created from the existing AutoCAD drawings.
Thank you very much in advance. 🙂
Replies (11)
Message 2 of 12
paullimapa
Do you mean a drawing with like a directory listing showing all the drawings in the current folder like dwg name, size, date ?
Paul Li
IT Specialist
@The Office
Message 3 of 12
Moshe-A
@mruPRQUJ  hi,
to create a list of files no lisp is need. you can google for applications that do that
or you can just use command prompt old and good DIR (directory) command to do it.
example:
c:\project01\dwg> dir *.dwg /b >michael.txt
this command will create (in 1 sec 🤣) "michael.txt" file containing a list of all dwg files in current folder.
[if you like, it can be called from any lisp program with (startapp) function]
the  greater then character redirect the output to file (instead of the console\screen)
the /b is to eliminate all info except for the files name.
enjoy
Moshe
Message 4 of 12
mruPRQUJ
yes, you are right, thanks a lot!  😀
Message 5 of 12
mruPRQUJ
I will try it later, thanks a million! 🙂
Message 6 of 12
paullimapa
Message 7 of 12
mruPRQUJ
Hi, I can’t thank you enough, I will check it later 🙂
Message 8 of 12
mruPRQUJ
It works, thanks a lot!
Message 9 of 12
mruPRQUJ
This lisp has more features, it can be inserted into DWGS. But I tried it, it did not work. I may make a mistake, many thanks.
Message 10 of 12
mruPRQUJ
It works, I made a mistake before, thanks a million! 🙂
Message 11 of 12
paullimapa
glad you got it to work....cheers!!!
Paul Li
IT Specialist
@The Office
Message 12 of 12
mruPRQUJ
I can't thank you enough, have a wonderful day! 🙂
