I have found a lisp that draws lines from the centre of the circles to adjacent line. Can someone modify it so that it can draw lines from block insertion point to adjacent line? Thanks in advance.
(defun c:foo (/ selection pline sscount objpline inspoint intpoint entity) (if (not (setq selection (ssget "_I" '((0 . "CIRCLE"))))) (progn (prompt "\nSelect circles: ") (setq selection (ssget '((0 . "CIRCLE")))) ) ) (setq pline (entsel "\nSelect polyline: ")) (if (and pline (setq objpline (vlax-ename->vla-object (car pline))) ) (repeat (setq sscount (sslength selection)) (setq entity (entget (ssname selection (setq sscount (1- sscount)))) inspoint (cdr (assoc 10 entity)) intpoint (vlax-curve-getclosestpointto objpline inspoint) ) (if intpoint (command "_.line" "non" inspoint "non" intpoint "") ) ) ) )
Solved by Kent1Cooper. Go to Solution.
Fortunately, the Insertion Point of a Block is stored in the same "slot" in its entity data as the center of a Circle, so it's a pretty simple addition of entity name:
(defun c:foo (/ selection pline sscount objpline inspoint intpoint entity) (if (not (setq selection (ssget "_I" '((0 . "CIRCLE,INSERT"))))) (progn (prompt "\nSelect circles: ") (setq selection (ssget '((0 . "CIRCLE,INSERT")))) ) ) (setq pline (entsel "\nSelect polyline: ")) (if (and pline (setq objpline (vlax-ename->vla-object (car pline))) ) (repeat (setq sscount (sslength selection)) (setq entity (entget (ssname selection (setq sscount (1- sscount)))) inspoint (cdr (assoc 10 entity)); both center of Circle and insertion pt of Block intpoint (vlax-curve-getclosestpointto objpline inspoint) ) (if intpoint (command "_.line" "non" inspoint "non" intpoint "") ) ) ) )
If you want only Blocks, and not both/either Circles and/or Blocks in the same command, use just "INSERT" instead of "CIRCLE,INSERT".
Either way, it would also accept other INSERT object types, such as Xrefs and some other oddball things [Windows Metafiles, for example] in the selection, but could be made fancier to accept only actual Block insertions, if needed.
Revised code. Changed ( 0 . CIRCLE) to ( 0 . INSERT) in order to select blocks instead of circles. let me know if this is what you were looking for
(vl-load-com)
(if (not (setq selection (ssget "_I" '((0 . "INSERT")))))
(progn
(prompt "\nSelect blocks: ")
(setq selection (ssget '((0 . "INSERT"))))
(if (and
pline
(setq
(if intpoint
