Drawing History
Drawing History
Message 1 of 11
Drawing History
This is a multi-part message in MIME format.
------=_NextPart_000_007E_01BF304F.C53B4A10
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Do I have access to the code that AutoCAD executes when I choose a =
recent file on the "File" menu and AutoCAD executes the open command on =
the file.
This operations seems to kill my acad.lsp and I get a message at the =
command prompt:
Lisp command not available.
Then none of my custom programs or the express tools work....
--=20
Rodney D. Lester
Systems Manager
GMS, Inc.
Content-Type: text/html;
http-equiv=3DContent-Type>
Do I have access to the code that =
AutoCAD executes=20
when I choose a recent file on the "File" menu and AutoCAD executes the =
open=20
command on the file.
This operations seems to kill my =
acad.lsp and I=20
get a message at the command prompt:
Lisp command not =
available.
Then none of my custom programs or the =
express=20
tools work....
Rodney D. Lester
Systems =
Manager
GMS, Inc.
------=_NextPart_000_007E_01BF304F.C53B4A10--
Replies (10)
Message 2 of 11
In a word - No, at least with AutoLISP.
Also, you cannot normally start a lisp program in one drawing and continue
it in a following drawing.
Some suggestions that may help otherwise:
1. Make sure that your directory and the express directory are listed in
Options/Files.
2. If you are using A2K, either set acadlspasdoc to 1, or
3. Rename your acad.lsp to acaddoc.lsp.
4. Explain your problem in a little more detail.
Dave D
(remove '-' for Email)
Rodney D. Lester wrote in article
<[email protected]>...
Do I have access to the code that AutoCAD executes when I choose a recent
file on the "File" menu and AutoCAD executes the open command on the file.
command prompt:
Rodney D. Lester
Systems Manager
GMS, Inc.
Message 3 of 11
The path to my custom programs directory is in Options/Files. acadlspasdoc
is set to 1. SDI is set to 1.
The only time I get the message is when I pick a drawing of the File|Drawing
History....
The acad.lsp file load as it should when I do a standard "Open"......
I don't know anything else to tell...
I have tried to change my acad.lsp to acaddoc.lsp - same results.......
Rodney D. Lester
Systems Manager
GMS, Inc.
David Doane wrote in message
news:01bf30b0$96445060$7a57d2d0@lms-1...
> Options/Files.
> Dave D
> command prompt:
> Rodney D. Lester
> Systems Manager
> GMS, Inc.
Message 4 of 11
Its seems as if it has something to do with the SDI... When set to 1 I have
the problems... If set to 0, the acad.lsp seems to load with each drawing...
Rodney D. Lester
Systems Manager
GMS, Inc.
Rodney D. Lester wrote in message
news:[email protected]...
File|Drawing
> History....
> Rodney D. Lester
> Systems Manager
> GMS, Inc.
continue
in
> > Options/Files.
> > Dave D
recent
file.
> > command prompt:
> > Rodney D. Lester
> > Systems Manager
> > GMS, Inc.
Message 5 of 11
Rodney,
I fear that I am at a loss. Everything I have gets loaded when selecting a
'history file' no matter how SDI is set, or how acadlspasdoc is set, just
as if I had typed 'open'.
Dave D
acadlspasdoc
File|Drawing
> History....
> Rodney D. Lester
> Systems Manager
> GMS, Inc.
continue
in
> > Options/Files.
> > Dave D
recent
file.
> > command prompt:
> > Rodney D. Lester
> > Systems Manager
> > GMS, Inc.
Message 6 of 11
Thanks anyway... I can't figure out whats going on...
Rodney D. Lester
Systems Manager
GMS, Inc.
news:01bf311d$8e68aae0$4256d2d0@lms-1...
> Rodney,
a
> Dave D
> acadlspasdoc
> File|Drawing
> > History....
> > Rodney D. Lester
> > Systems Manager
> > GMS, Inc.
> continue
> in
> > > Options/Files.
> > > Dave D
> recent
> file.
> > > command prompt:
> > > Rodney D. Lester
> > > Systems Manager
> > > GMS, Inc.
Message 7 of 11
Does anyone have any idea what command is being run when selecting a drawing
from the Drawing History in the file menu?
I assume that AutoCAD is running a routine to flesh out the history, and
somehow running "Open" with the included drawing name, but am at a loss as
to what and how it's running.
Why does this matter? Just ties into issues dealing with search paths.
Any other menu selection has a command associated with it (with the
exception of "Send..."). The Drawing History menu selection looks more like
a menu title, i.e.:
ID_MRU [Drawing History]
looks more like:
ID_MnFile [&File]
as opposed to:
ID_APP_EXIT [E&xit]^c^c_quit
Failing that, how can I disable it without making any modifications to the
acad menu itself?
I can disable any menu item that I want by using (reference the above
example for the exit selection):
(menucmd "Gacad.ID_APP_EXIT=~")
But this fails on the Drawing History selection because what actually exists
there is a list of created from the registry, and I don't know how to
address them.
BTW, Have also tried (menucmd "P1.21=~") just to see if it would work (with
various values in the "21" slot) to no avail...
Any help would be appreciated.
Gary J. Orr
CADD Manager
(218) 279-2421
[email protected]
LHB Engineers and Architects
21 West Superior Street, Suite 500
Duluth, Mn 55802
(218) 727-8446
www.LHBcorp.com
Message 8 of 11
As you noted, changing the menu isn't going to help you any. However, you
can disable it by setting the number of drawings in the MRU to 0. In
Options>Open and Save tab, set 'number of recently used files to list' to 0.
You can do it programattically using vlisp to access
AcadPreferencesOpenSave.MRUNumber.
Ed
"Gary J. Orr" wrote in message
drawing
like
> a menu title, i.e.:
> looks more like:
> ID_MnFile [&File]
> as opposed to:
> acad menu itself?
exists
> address them.
(with
> Gary J. Orr
> CADD Manager
> (218) 279-2421
> [email protected]
> Duluth, Mn 55802
> (218) 727-8446
> www.LHBcorp.com
Message 9 of 11
Not only good but fast as well...
Thanx
Gary J. Orr
CADD Manager
(218) 279-2421
[email protected]
Duluth, Mn 55802
(218) 727-8446
www.LHBcorp.com
"Ed Jobe" wrote in message
0.
> Ed
> drawing
as
> like
> > a menu title, i.e.:
> > looks more like:
> > ID_MnFile [&File]
> > as opposed to:
the
> > acad menu itself?
> exists
> > address them.
> (with
> > Gary J. Orr
> > CADD Manager
> > (218) 279-2421
> > [email protected]
> > Duluth, Mn 55802
> > (218) 727-8446
> > www.LHBcorp.com
Message 10 of 11
For anyone else watching, here is a method to set the value:
(setenv "MRUFilesToList" "0")
Gary J. Orr
CADD Manager
(218) 279-2421
[email protected]
Duluth, Mn 55802
(218) 727-8446
www.LHBcorp.com
> Thanx
> Gary J. Orr
> CADD Manager
> (218) 279-2421
> [email protected]
> Duluth, Mn 55802
> (218) 727-8446
> www.LHBcorp.com
you
to
> 0.
> > Ed
> > drawing
and
loss
> as
> > like
> > > a menu title, i.e.:
> > > looks more like:
> > > ID_MnFile [&File]
> > > as opposed to:
> the
> > > acad menu itself?
> > exists
> > > address them.
> > (with
> > > Gary J. Orr
> > > CADD Manager
> > > (218) 279-2421
> > > [email protected]
> > > Duluth, Mn 55802
> > > (218) 727-8446
> > > www.LHBcorp.com
Message 11 of 11
PS Don't set it above 9 unless you want to waste a little time next morning
figuring why Acad won't run. 🙂
Gary J. Orr wrote in message
> Gary J. Orr
> CADD Manager
> (218) 279-2421
> [email protected]
> Duluth, Mn 55802
> (218) 727-8446
> www.LHBcorp.com
> > Thanx
> > Gary J. Orr
> > CADD Manager
> > (218) 279-2421
> > [email protected]
> > Duluth, Mn 55802
> > (218) 727-8446
> > www.LHBcorp.com
> you
> to
> > 0.
> > > Ed
> > > drawing
> and
> loss
> > as
paths.
more
> > > like
> > > > a menu title, i.e.:
> > > > looks more like:
> > > > ID_MnFile [&File]
> > > > as opposed to:
to
> > the
> > > > acad menu itself?
above
actually
> > > exists
to
> > > > address them.
work
> > > (with
> > > > Gary J. Orr
> > > > CADD Manager
> > > > (218) 279-2421
> > > > [email protected]
> > > > Duluth, Mn 55802
> > > > (218) 727-8446
> > > > www.LHBcorp.com
