Drawing a line....!
Drawing a line....!
robw
Drawing a line....!
robw
Hi, this is a silly thing to fall over on, but it's been a long time since I looked at Lisp.
All I want to do is create a button on my ribbon that when pressed, draws a polyline on a layer using a LTS of 0.25, then returns the user to the previous layer and resetting the LTS back to 1.0.
Assume the new layer already exists in the drawing (I use STEALv1-8.lsp to import the layer, after the defun command).
All I've got is:
(defun c:drawline_non-printing ( )
(setvar 'clayer "- non printing")
(command "_pline")
(princ)
Hahaha
Any help / ideas?
Civil 2018
ВeekeeCZ
(defun c:drawline_non-printing (/ l s )
  (setq l (getvar 'clayer)
	s (getvar 'celtscale))
  (or (tblsearch "LAYER" "- non printing") ; does it exist?
      (command "_.layer" "_n" "- non printing" "_plot" "_no" "" ""))  ; Create new if not
  (setvar 'celtscale 0.25)
  (command-s "_pline")
  (setvar 'clayer l)
  (setvar 'celtscale s)
  (princ)
robw
You are a star!
Moshe-A
@robw  hi,
how about that?
(defun c:drawline_non-printing (/ savCLayer layerName savLTScale)
 (setq savCLayer (getvar 'clayer))
 (setq layerName "- non printing")
 (setq savLTScale (getvar 'ltscale))
 (setvar 'ltscale 0.25)
 (if (tblsearch "layer" layerName)
  (command "._layer" "_m" layerName "_plot" "_no" "" "")
 (command-s "._pline")
 (setvar 'ltscale savLTScale)
 (setvar 'clayer savCLayer)
 (princ)
Kent1Cooper
Another way, without having to save and restore anything:
(defun c:drawline_non-printing ()
(command "_.chprop" "_last" "" "_layer" "- non printing" "_ltscale" 0.25 "") (princ) )
Kent Cooper, AIA
rrowe24N24
got a question
when I'm trying to manually stretch or trim a wire/line it is not staying straight.
how can I correct this.
is there a setting in object snap
ВeekeeCZ
@rrowe24N24 wrote:
got a question
How is this related to the topic?
Start a new topic, please.
