draw polyline between 2 blocks
atawk
atawk
I want a lisp that does the following:
1. select block1 with basepoint pt1
2. select block2 with basepoint pt2
3. draw a polyline between pt1 and pt2
dlanorh
Try this.
(defun c:jbp (/ _get_ent _em_lwp p1 p2)
  (defun _get_ent (msg / r j h)
    (while (not h)
      (setq r (car (entsel (strcat "\nSelect " msg " Block : "))))
      (if (= (cdr (assoc 0 (setq j (entget r)))) "INSERT") (setq h (cdr (assoc 10 j))) (alert "Not a Block"))
    );end_while
    h
  );end_defun
(defun _em_lwp (lst)
  (entmakex (append (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") (cons 90 (length lst)))
                    (mapcar '(lambda ( x ) (cons 10 x)) lst)
            );end_append
  );end_entmakex
);end_defun
  (setq p1 (_get_ent "First")
        p2 (_get_ent "Second")
  );end_setq
  (_em_lwp (list p1 p2))
  (princ)
);end_defun
I am not one of the robots you're looking for
Kent1Cooper
How about something a little simpler?  Instead of selecting the Blocks and having it ferret out their insertion points, just Osnap to their insertion points directly:
(defun C:WHATEVER ()
  (command "_.pline" "_ins" pause "_ins" pause "")
No variables required, no sub-routines, etc.
Apart from your question, I have one:  Is there some reason not to draw just an ordinary Line?  A single-line-segment Polyline takes considerably more memory than a Line, so if you don't need to give it width, a Line is better.
Kent Cooper, AIA
Sea-Haven
Two or more using same idea of pause.
(defun C:WHATEVER ( / oldsnap)
(setq oldsnap (getvar 'osmode))
(setvar 'osmode 64)
(princ "\nPick blocks C or Enter to stop")
(command "_pline" )
(while (= (getvar "cmdactive") 1 ) (command pause))
(setvar 'osmode oldsnap)
atawk
thanks a lot it works fine for me.
is there a possibility upgrade it so we can select more than two blocks at once?
Sea-Haven
Read my post again !!!
Kent1Cooper
If by "select...at once" you mean by something like a window, rather than one at a time, then you would need to define some criteria by which a routine could determine the order  in which to connect their insertion points.
Kent Cooper, AIA
