DRAW POLYLINE & INSERT BLOCK LISP
Sunny2006
Message 1 of 8
Sunny2006
please i  need a  help write a lisp
selecting point1 ( on blank space )
Point 2 On a polyline
Is possible to write a lisp that draws a  L shape polyline and insert the block on the polyline line
Replies (7)
Message 2 of 8
Sea-Haven
Yes very easy, a good learning exercise, so have a go. We are here to help.
Pick a point
Pick a second point for direction
Pick a point for side direction
Then break line putting gap, use polar for gap width
Add block, side direction determines if you need to mirror.
Draw yellow pline use Polar command to work out points for new pline.
Message 3 of 8
Kent1Cooper
... or build the Block with a wipeout in it, so you don't need to Break the original object.
Kent Cooper, AIA
Message 4 of 8
Sunny2006
When I use Wipeout blocks, I can't able to make automatic Dimension, by using lisps ;
Message 5 of 8
Sea-Haven
Did you make it work ?
Message 6 of 8
Sunny2006
I am not that advanced in coding 😞
A modified code of existingcode here ;
(defun c:Branch ( / p r Usersnap)
(if (and (setq p (getpoint "\nSTARTING POINT: "))
(setq Usersnap (getvar 'osmode))
(setvar 'osmode 128)
(setq r (getpoint p "\nPIPE BREAK POINT: ")))
(progn
(command "_.insert" "VRF YEE" "_s" 1 "_r" (angtos (+ (/ pi 2) (angle r p))) "_non" r
"_Pline" "_j" "_z" "_s" 20 "_non" p "_non" (polar r (angle r p) 25.5) "")
(setvar 'osmode Usersnap))
(princ)
Message 7 of 8
Sea-Haven
Your dimensions look for a line with a break in them, your code does not break ? Once you do that you can not join the plines. Use points p and r to break. Also use osmode 512 for both pick points.
Message 8 of 8
Kent1Cooper
@Sunny2006 wrote:
"_Pline" "_j" "_z" "_s" 20 ....
Those look like answers to prompts in a MLINE command [Justification Zero, Scale 20], not a PLINE command.  Unlike MLINEs, PLINEs don't have justification choices -- their Width [not Scale] is always centered around the defining points [like Zero Justification in MLINE].  And if you're intending a Width setting, you don't get that option until after the first point has been given, and you need to give it two responses for the beginning and end of the segment.  What are you really trying to do?
Kent Cooper, AIA
