Draw poiyline using a list containing X, Y coordinate
Message 1 of 15
Hello, all. I am a beginner of AutoCAD lisp.
I have two simple questions
1. I generate a list which containing X Y coordinate such as:
Coor = (100 10 101 12 103 32)
which means X1 = 100, Y1 = 10, X2 = 101, Y2 = 12, X3 = 103, Y3 = 32.
Here, how can I make lisp code to work as like:
(COMMAND "PLINE" "100,10" "101,12" "103,32" "")
2. Through the web search, I understand there are several methods to draw pline from the list as like:
Coor_1 = ((100 10) (101 12) (103 32))
Here, how can I change the list format from Coor (original one in above #1) to Coor_1?
Thank you. Cheers,
Replies (14)
Message 2 of 15
I've find the solution by myself. Thanks.
Message 3 of 15
Discussion_Admin
Can you post the solution to share with other searching ???
Discussion_Admin
Message 4 of 15
john.uhden
Just to perhaps confirm what you found, Coor is called a flat list (x1 y1 x2 y2 xn yn) whereas Coor_1 is a 2D list (a list of 2D points).
The flat list is what you need if you want to use (vla-addlightweighrpolyline ...).
The 2D list is handy if you want to use (command ".pline" (mapcar Coor_1) "")
The 2D list can be converted into a flat list by (apply 'append Coor_1).
The flat list can be converted into a 2D list by grouping the list in pairs...
  (defun @group (old n / item new)
    (while old
      (while (< (length item) n)
        (setq item (cons (car old) item) old (cdr old))
      (setq new (cons (reverse item) new) item nil)
    (reverse new)
Such as (@group Coor 2)
which can also be used for 3D flat lists, as in
(@group flatlist 3)
John F. Uhden
Message 5 of 15
Kent1Cooper
This can actually be a lot simpler than you might think.  The 'Coordinates VLA Property of a LWPolyline is just such a "flat list," and can be imposed on a Polyline, even one without the same number of vertices.  The coordinates do need to be real numbers, though, not integers.  The following makes that conversion, and draws a temporary minimal Polyline, then imposes those coordinates on it.  The PLINETYPE System Variable needs to be other than 0, because a "heavy" Polyline needs XYZ coordinates, not just XY.
(vl-load-com); if not already loaded
(setvar 'plinetype 2); in case it happens to be 0
(setq Coor (mapcar 'float Coor))
(command "_.pline" (getvar 'viewctr) "@1,0" "")
(vlax-put (vlax-ename->vla-object (entlast)) 'Coordinates Coor)
This has an additional benefit over any approach that breaks up the list into point lists and uses them in a PLINE command, that this doesn't require any accounting for whether any Object Snap modes are running.
Kent Cooper, AIA
Message 6 of 15
john.uhden
Excellent!  That's actually the way I usually do it, though sometimes I will use entmake because I can include the desired layer name without any additional code, plus plinewid and closed.  Actually, entmake followed by putting the coordinates is probably the best and easiest.  The last step is to setbulge.
John F. Uhden
Message 7 of 15
martti.halminen
Another way to make a 2D list:
(defun pairify (l)
  ;; (a b c d...) -> ((a b)(c d) ...)
  (cond ((null l) nil)
        (T (cons (list (car l) (cadr l)) (pairify (cddr l))))))
Message 8 of 15
john.uhden
But then you need a tripify function, or maybe trioify for heavies or 3Ds.
John F. Uhden
Message 9 of 15
Ranjit_Singh
arz6oiof wrote:...........
There can be many possible ways as suggested above by other members. Here is one example
Command: (setq Coor '(100 10 101 12 103 32))
Command: (mapcar '(lambda (x y) (list x y)) Coor (cdr Coor))
((100 10) (10 101) (101 12) (12 103) (103 32))
To make a pline from this list,
(apply 'command (append '("._pline") (mapcar '(lambda (x y) (list x y)) Coor (cdr Coor)) '("")))
Message 10 of 15
phanaem
Ranjit, your list has 5 vertexes, not 3, like it should be (= list_length / 2), so it is not the same polyline.
Message 11 of 15
Ranjit_Singh
phanaem wrote:...
Ranjit, your list has 5 vertexes, not 3, like it should be (= list_length / 2), so it is not the same polyline...
Thanks for the correction. I have adjusted my code
(setq Coor '(100 10 101 12 103 32) ctr 1)
(apply 'command
               (vl-remove nil
                                    (if (minusp (setq ctr (- ctr)))
                                     (list x y)))
                                  coor
                                  (cdr coor)))
Message 12 of 15
DannyNL
Just for fun and info.
Lee Mac has written two nice short solutions to convert number lists to 2D or 3D point lists.
(defun LM:lst->3DPoint ( l ) ;; © Lee Mac 2010
   (if
      l
      (cons (list (car l) (cadr l) (caddr l)) (LM:lst->3DPoint (cdddr l)))
(defun LM:lst->2DPoint ( l ) ;; © Lee Mac 2010
   (if
      l
      (cons (list (car l) (cadr l)) (LM:lst->2DPoint (cddr l)))
Message 13 of 15
phanaem
Not sure if Lee Mac should be credited for these functions. Even in this topic there is a similar one.
He could write them from scratch, I know I did, but I guess so did many others, way before us.
If the speed matters, here is an alternative, 5 times faster (tested on 2000 points polyline)
(defun list->2Dpoints (l / a b r)
  (foreach b l
    (cond
      (a (setq r (cons (list a b) r) a nil))
      (T (setq a b))
  (reverse r)
(defun list->3Dpoints (l / a b c r)
  (foreach c l
    (cond
      (b (setq r (cons (list a b c) r) a nil b nil))
      (a (setq b c))
      (T (setq a c))
  (reverse r)
Message 14 of 15
DannyNL
Yep, that would be another way. There are multiple way to achieve the same.
Although these functions are pretty straightforward and could be written by anyone with average LISP knowledge, the code examples I posted were written by Lee Mac. I just copied and pasted, so I think it is more than fair to mention credit him since I didn't write them myself.
And since I do not work very often with lists that contain over 100 points, they are more than sufficient for my needs. In my case I'm not interested in faster if that means a difference of a couple of milliseconds Smiley Happy
Message 15 of 15
phanaem
Fair enough.
For the sake of truth, the posted lisp is not 5 times faster, it's less than 2. The test I did wasn't accurate.
