Draw Coordinates in mtext starting from lines
I have lines in autocad and I am trying to make a function where the user can select all lines and the program finds the start vertices of these lines and draw the point coordinates.
Is it possible to get the Start X Y of these lines?
I tryed this XY_leader.lsp that draw the coordinate clicking on single points. I search something similar but automatic and with lines.
Thanks a lot for the help!
pbejse
building off the XY_leader attachement
(Defun c:demo ( / XY_leader SS_Lines e sp ep)
  (defun XY_leader (p1 p2 /)
    (setvar "DYNMODE" 1)
    (vl-cmdf "_leader"
	     "_non"
	     p1
	     "_non"
	     p2
	     (strcat "X = " (rtos (car p1) 2 2))
	     (strcat "Y = " (rtos (cadr p1) 2 2))
  (if
    (setq SS_Lines (ssget '((0 . "*LINE"))))
     (repeat (Setq i (sslength SS_Lines))
       (setq e (ssname SS_Lines (setq i (1- i))))
       (setq sp	(Vlax-curve-getstartpoint e)
	     ep	(Vlax-curve-getEndpoint e)
       (setq ang
	      (if
		(> (car sp) (Car ep))
		 (* 60 (/ pi 180))
		 (* 120 (/ pi 180))
       (XY_leader sp (polar sp ang (* 5.0 (getvar 'Textsize))))
HTH
Thank you very much! it was exactly what I was looking for!
