draw 3D polyline using coordinates
Yamishon_Noah
Yamishon_Noah
I want to draw 3D polyline in coordinates,
I have coordinates in excel.
Ex:
1st 3D polyline
X object to Y object
draw 3D polyline as per co-ordinates (have in excel)
2nd 3D polyline
Z object to Y object
like I need to draw many 3D polylines in coordiantes
is there any LISP for this process?
kindly let me know
thanks
nichkherbsman
This is the code that you are looking for.
Credit to cadtips.cadalyst.com - Tony Hotchkiss.
(defun err (s)
  (if (= s "Function cancelled")
    (princ "IMPORT-3D-POLY - cancelled: ")
    (progn (princ "IMPORT-3D-POLY - Error: ")
	   (princ s)
	   (terpri)
    ) ;_ progn
  ) ; if
  (resetting)
  (princ "SYSTEM VARIABLES have been reset\n")
  (princ)
) ; err
(defun setv (systvar newval)
  (setq x (read (strcat systvar "1")))
  (set x (getvar systvar))
  (setvar systvar newval)
) ; setv
(defun setting ()
  (setq oerr *error*)
  (setq *error* err)
  (setv "CMDECHO" 0)
  (setv "BLIPMODE" 0)
) ; end of setting
(defun rsetv (systvar)
  (setvar systvar (eval x))
) ; restv
(defun resetting ()
  (rsetv "CMDECHO")
  (rsetv "BLIPMODE")
  (setq *error* oerr)
) ; end of resetting
(defun poly3D ()
  (setq	ptlist1	(get-ptlist))
  (make-3dpolyline ptlist1)
) ;_ poly3D
(defun get-ptlist ()
  (setq	fn    (getfiled "3D points file" "" "txt" 8)
	f     (open fn "r")
	str   (read-line f)
	plist nil
  ) ;_ end of setq
  (while (/= str EOF)
    (setq str (read-line f))
    (if	str
      (progn
	(setq pt (get-pt str))
	(setq plist (append plist (list pt)))
      ) ;_ end of progn
    ) ;_ end of if
  ) ;_ end of while
  (setq f (close f))
  plist
) ;_ get-ptlist
(defun get-pt (str1)
  (setq	comma (chr 44)
	str2  ""
	count 1
	i     0
  ) ;_ end of setq
  (repeat 2
    (repeat (strlen str1)
      (setq char (substr str1 (setq i (1+ i)) 1))
      (if (/= char comma)
	(setq str2 (strcat str2 char))
	(progn
	  (if (= count 1)
	    (progn
	      (setq x (atof str2))
	      (setq str1 (substr str1 (1+ i)))
	      (setq i 0)
	      (setq count 2)
	      (setq str2 "")
	    ) ;_ end of progn
	    (progn
	      (setq y (atof str2))
	      (setq z (atof str1))
	    ) ;_ end of progn
	  ) ;_ end of if
	) ;_ end of progn
      ) ;_ end of if
    ) ;_ end of repeat
  ) ;_ end of repeat
  (setq pt (list x y z))
) ;_ end of get-pt
(defun make-3dpolyline (ptlist)
  (entmake (list '(0 . "POLYLINE")
		 '(100 . "AcDbEntity")
		 '(100 . "AcDb3dPolyline")
		 '(70 . 8)
	   ) ;_ list
  ) ;_ entmake
  (repeat (length ptlist)
    (setq pt	 (car ptlist)
	  ptlist (cdr ptlist)
    ) ;_ setq
    (entmake (list '(0 . "VERTEX")
		   '(100 . "AcDb3dPolylineVertex")
		   (cons 10 pt)
		   '(70 . 32)
	     ) ;_ list
    ) ;_ entmake
  ) ;_ repeat
  (entmake '((0 . "SEQEND")))
) ;_ make-3dpolyline
(defun c:pl3 ()
  (setting)
  (poly3D)
  (resetting)
  (princ)
) ;_ c:pl3
(prompt "Enter PL3 to start")
For for information see the link below:
http://cadtips.cadalyst.com/3d-operations/import-3d-points-excel
Jah
NiCHKCiD
BIM Modeler
Technical Officer
Technical Designer
Sr. Draftsman
Yamishon_Noah
you're awesome...
pls see my query (want to do)
Create a layer
  many layer want to create
Create a 3D polyline using coordiantes  (you provided lisp for it)
  Each 3D polyline has max 10 points to create
  No. of 3D polyline to be create is more than 1000 hence we need to run every polyline individually - any other alter solution ?
  Should place drawn 3D polyline  in respective layer
Attach a tag to 3d polyline created - I have lisp for it (FAS file)
  Each 3D polyline has individual tag
how to compile all these steps together... I want to setup all these in excel file or csv or txt file as a input for this LISP and LISP should call that file and execute it..
Kindly help me,,
nichkherbsman
Thank you.
That's a combination of 3 lisp.
Can you attach your lisp that you said. the FAS file.
And can you attach the dwg file that you want to draw.
Thank you.
NiCHKCiD
BIM Modeler
Technical Officer
Technical Designer
Sr. Draftsman
Yamishon_Noah
Pls find attached file
I have attached sample dwg
   Ex: only one 3D polyline drawn
         Similarly there are many 3D polylines to be drawn.
I have added TAG for that 3D polyline also.
nichkherbsman
I saw the file you attached. Thank you for that.
Anyway, I suggest that you start draw the 3D polylines and put manually the tags and layer using the lisp you have.
I'm still trying to figure how will happen the lisp you want, like in one cmd.
Jah
NiCHKCiD
BIM Modeler
Technical Officer
Technical Designer
Sr. Draftsman
Yamishon_Noah
Hi jah,
I'm figuring out like below... give me your suggestion on this too
(defun c:mk ()
(command "_layer" "n" "JB1" "")
(command "_layer" "c" "3" "JB1" "")
(command "_layer" "s" "JB1" "")
(command "_3dpoly" "100,100,0" "250,250,0" "250,250,750" "")
(princ)
here I can define many 3D polylines & layers can draw it.
only thing I could call another LISP command in this lisp.. - you have any solution for this?
