double offset lisp
I found this double offset lisp by Lee Mac, very useful. Although any way to modify it in such a way that it would offset asking the total distance of two lines instead of regular offset. example, I need to offset lines to draw pipe, dia of pipe say 273. Command "double offset" distance 273.
;;--------------------=={ Double Offset }==-------------------;;
;; Offsets each object in a selection to both sides by a ;;
;; specified distance. With additional controls for erasure ;;
;; of source object and offset layer. ;;
;; Author: Lee Mac, Copyright © 2011 - www.lee-mac.com ;;
;; Version: 1-1 20100912 ;;
(defun c:DOff nil (c:DoubleOffset))
(defun c:DoubleOffset ( / *error* _StartUndo _EndUndo DoubleOffset doc exitflag layer mpoint obj object of point sel symbol value )
(defun *error* ( msg )
(and doc (_EndUndo doc))
(or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")
(princ (strcat "\n** Error: " msg " **")))
(princ)
(defun _StartUndo ( doc ) (vla-StartUndoMark doc))
(defun _EndUndo ( doc ) (if (= 8 (logand 8 (getvar 'UNDOCTL))) (vla-EndUndomark doc)))
(defun DoubleOffset ( object offset layer )
(mapcar
(function
(lambda ( o )
(if
(and
(not
(vl-catch-all-error-p
(setq o
(vl-catch-all-apply
(function vlax-invoke) (list object 'Offset o)
layer
(mapcar
(function
(lambda ( o )
(vla-put-layer o (getvar 'CLAYER))
o
(list offset (- offset))
(setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))
(mapcar
'(lambda ( symbol value ) (or (boundp symbol) (set symbol value)))
'(*dOff:Erase *dOff:Layer) '("No" "Source")
(if
(progn
(while
(progn
(princ
(strcat
"\nCurrent Settings: Erase source="
*dOff:Erase
" Layer="
*dOff:Layer
" OFFSETGAPTYPE="
(itoa (getvar 'OFFSETGAPTYPE))
(initget 6 "Through Erase Layer")
(setq of
(getdist
(strcat "\nSpecify Offset Distance [Through/Erase/Layer] <"
(if (minusp (getvar 'OFFSETDIST)) "Through" (rtos (getvar 'OFFSETDIST))) "> : "
(cond
(null of) (not (setq of (getvar 'OFFSETDIST)))
(eq "Through" of) (setq of (setvar 'OFFSETDIST -1)) nil
(eq "Erase" of) (initget "Yes No")
(setq *dOff:Erase
(cond
(getkword
(strcat "\nErase source object after offsetting? [Yes/No] <" *doff:Erase "> : ")
( *dOff:Erase )
(eq "Layer" of) (initget "Current Source")
(setq *dOff:Layer
(cond
(getkword
(strcat "\nEnter layer option for offset objects [Current/Source] <" *dOff:Layer "> : ")
( *dOff:Layer )
( of (setvar 'OFFSETDIST of) nil )
of
(while
(progn
(or ExitFlag
(progn (initget "Exit")
(setq sel (entsel "\nSelect object to offset or [Exit] <Exit> : "))
(cond
(or ExitFlag (null sel) (eq sel "Exit")) nil
( (vl-consp sel)
(_EndUndo doc) (_StartUndo doc)
(if (and (wcmatch (cdr (assoc 0 (entget (car sel)))) "ARC,CIRCLE,ELLIPSE,SPLINE,LWPOLYLINE,XLINE,LINE")
(setq obj (vlax-ename->vla-object (car sel))))
(if (minusp of)
(if
(progn (initget "Exit Multiple")
(and
(setq point (getpoint "\nSpecify through point or [Exit/Multiple] <Exit> : "))
(not (eq "Exit" point))
(if (eq "Multiple" point)
(while
(setq mpoint (getpoint "\nSpecify through point or [Exit] <next object> : "))
(cond
(eq "Exit" mpoint)
(if (eq "Yes" *dOff:Erase) (vla-delete obj))
(not (setq ExitFlag t))
(null mpoint)
nil
(listp mpoint)
(DoubleOffset obj
(distance (trans mpoint 1 0)
(vlax-curve-getClosestPointto (car sel) (trans mpoint 1 0) t)
(eq "Current" *dOff:Layer)
t
(progn
(DoubleOffset obj
(distance (trans point 1 0)
(vlax-curve-getClosestPointto (car sel) (trans point 1 0) t)
t
(setq ExitFlag t)
(progn
(DoubleOffset obj of (eq "Current" *dOff:Layer))
(princ "\n** Cannot Offset that Object **")
t
(_EndUndo doc) (princ)
(vl-load-com) (princ)
(princ "\n:: DoubleOffset.lsp | Version 1.1 | © Lee Mac 2011 www.lee-mac.com ::")
(princ "\n:: Type \"DoubleOffset\" or \"DOff\" to invoke ::")
(princ)
;; End of File ;;
