DOSLib for AutoCAD 2021 Available
dale_fugier
Message 1 of 30
dale_fugier
If anyone is interested...or cares... 😉
http://wiki.mcneel.com/doslib/home
https://github.com/dalefugier/DOSLib
28 years and counting...
Hope everyone is safe and healthy.
-- Dale
Replies (29)
Message 21 of 30
averdam
Hi Dale,
Is there already a doslib update for autocad 2022
Met vriendelijke groeten,
Ard
Message 22 of 30
dale_fugier
Message 23 of 30
averdam
Message 24 of 30
diegus68
Thanks.
how do i install the code?
Message 25 of 30
mnelson
add the ARXload statement to your AutoCAD startup, usually ACAD.lsp file.
(arxload "doslib24x64.arx")
if you multiple versions of AutoCAD:
;; Load 64 bit DOS Library files
(setq _acadver (substr (getvar "acadver") 1 2))
(cond
((= _acadver "20") (arxload "doslib20x64.arx"))
; AutoCAD 2015-2016 DOS library
((= _acadver "21") (arxload "doslib21x64.arx"))
; AutoCAD 2017 DOS library
((= _acadver "22") (arxload "doslib22x64.arx"))
; AutoCAD 2018 DOS library
((= _acadver "23") (arxload "doslib23x64.arx"))
; AutoCAD 2019-2020 DOS library
((= _acadver "24") (arxload "doslib24x64.arx"))
; AutoCAD 2021-22 DOS library
(t nil)
Message 26 of 30
diegus68
I did something wrong
I get "Error: bad argument type: streamp nil"
I want to cry
Command:
Command: _appload DOSLib23x64.arx already loaded.
MultiFileTool.lsp successfully loaded.
Command:
Multi File Tool loaded. Use: MFT to start.
Command:
Command: MFT
; MultiFileTool - build: 031011
; *** AutoCAD MFT v3.1 ***
; Copyleft 😉 2004-2020 | Roland Rothenhöfer
; Configuration file for MultiFileTool (MFT)
[config]
; ------------------------------------ END -------------------------------------
Command:
Message 27 of 30
sby0531
Where can I find the Help Manual file DOSLib.chm for AutoCAD 2021? Thank you!
Message 28 of 30
averdam
Hello, is this wat you looking for?
Message 29 of 30
cadffm
Hi sby,
the doslib.chm is part of the 2021- .zip file (Version 9.0.3) and it was the last .chm, far as I know.
@averdam
"this" is "nothing", nothing linked, nothing attached!
Log in via browser and post it again pls
Sebastian
Message 30 of 30
MOatman
