Visual LISP, AutoLISP and General Customization
DOS commands in lisp
13 REPLIES 13
Message 1 of 14
2873 Views, 13 Replies
Does anyone know where I go to learn about the "shell" command. I want to
be able to run a DOS commands from lisp.
Tom
13 REPLIES 13
Message 2 of 14
ignore this test
"Tom" wrote in message
news:F46F5BD6DCE549A5623D97CCC97A68CB@in.WebX.maYIadrTaRb...
> Tom
Message 3 of 14
It would be useful to see a lisp routine that someone has writen that
includes the use of DOS commands.
Tom
Message 4 of 14
Here is a not very useful but perhaps instructive example.
;MAKE DIRECTORY NAME WITH SPACE CHARACTERS IN IT
(defun c:tdir ()
(command "shell" (strcat "mkdir " (chr 34) "c:\\temp\\my test1" (chr 34)))
Cliff
news:FABC2365863700810B5BA394E56AE779@in.WebX.maYIadrTaRb...
> Thanks,
> Tom
Message 5 of 14
BillZ
Hi Tom,
Dos_lib is a free application from Mcneel.com that allows you to run dos functions seemlessly inside autolisp.
It also includes some GUI, system and printer functions.
here's asnip from one of my programs,
>>> (dos_command "sort/+7<>g:\\autolisp\\lisp_text\\nflst1.txt" 3)
Enjoy!
BillZ
Message 6 of 14
What do you want to see? I've usually found it easier to write a batch
file from LISP then call the batch file using SHELL.
Sincerely,
Darren J. Young
Minnesota CADWorks, Inc.
P.O. Box 7293
Saint Cloud, Minnesota 56302-7293
Phone: (320) 654-9053
WWW: http://www.mcwi.com
Message 7 of 14
the setback of using shell is lisp doesn't hold on.
if you wnat for example to create a directory sometimes it is not yet
created if you need it.
> Sincerely,
> Darren J. Young
> P.O. Box 7293
Message 8 of 14
This can be solved easily a couple ways. One of the oldest tricks in the
book is to create a semaphore in disk and loop your code until it's gone.
You'r batch file would delete it after it's done processing. Of course,
there's more elegant ways to do this sort of thing now.
Another way, is to place a shortcut in your PGP file to call the shell
and set it up to have AutoCAD wait until it returns from the shell. Your
lisp would then call the shortcut.
Sincerely,
Darren J. Young
P.O. Box 7293
Message 9 of 14
i know the solutions but as you said it yourself they are not the most
elegant and since there are vlisp functions there are not manny occasions
you need the dos functions
Darren J. Young schreef in berichtnieuws
MPG.16828cef320ac4b3989f83@discussion.autodesk.com...
> Sincerely,
> Darren J. Young
> P.O. Box 7293
Message 10 of 14
Tom,
Here are some old routines I used to use. They are not elegant, but they
work. Now I use DOSLib or VLISP. Hope this helps.
(DEFUN DELFILE (FLIST /)
(SETQ DELFIL "C:\\DELFILE.BAT"
DFILE (OPEN DELFIL "w")
(WRITE-LINE "@ECHO OFF" DFILE)
(WRITE-LINE (STRCAT "ECHO Deleting " FLIST) DFILE)
(WRITE-LINE (STRCAT "DEL " FLIST) DFILE)
(CLOSE DFILE)
(COMMAND "SHELL" "C:\\DELFILE")
(PRINC)
(DEFUN RENFILE (RFILE1 RFILE2 /)
(SETQ RENFIL "C:\\RENFILE.BAT"
RFILE (OPEN RENFIL "w")
(WRITE-LINE "@ECHO OFF" RFILE)
(WRITE-LINE (STRCAT "ECHO Renaming " RFILE1 " to " RFILE2) RFILE)
(WRITE-LINE (STRCAT "RENAME " "\"" RFILE1 "\"" " " "\"" RFILE2 "\"")
RFILE)
(CLOSE RFILE)
(COMMAND "SHELL" "C:\\RENFILE")
(PRINC)
(DEFUN SRTFILE (SFILE1 SFILE2 /)
(SETQ SLIST NIL
SOURCE (OPEN SFILE1 "r")
SLINE (READ-LINE SOURCE)
SLIST (LIST SLINE)
COUNT 0
(WHILE SLINE
(SETQ SLINE (READ-LINE SOURCE)
SLINE2 (LIST SLINE)
(IF SLINE (SETQ SLIST (APPEND SLIST SLINE2)))
(SETQ COUNT (+ COUNT 1))
(SETQ SLIST (REVERSE (ACAD_STRLSORT SLIST)))
(CLOSE SOURCE)
(SETQ DESTIN (OPEN SFILE2 "w"))
(REPEAT COUNT
(SETQ COUNT (- COUNT 1)
DLINE (NTH COUNT SLIST)
(WRITE-LINE DLINE DESTIN)
(CLOSE DESTIN)
(PRINC)
Daniel J. Altamura, R.A.
Altamura Architectural Consulting
and SoftWorx, Autodesk Registered Developer
DAltamura@compuserve.com
> Thanks,
> Tom
Message 11 of 14
Where do I find out more about visual lisp?
Tom
"Paul" wrote in message
news:4EB0D27C0C2511E3F5C220B18054402E@in.WebX.maYIadrTaRb...
gone.
> > Sincerely,
> > Darren J. Young
> > P.O. Box 7293
Message 12 of 14
helpfiles?
Message 13 of 14
jpCADconsulting
Hi folks, I've been trying to issue this DOS commadn from acad.lsp without much luck:
net config server /autodisconnect:-1
I'm sure it's a syntax issue, what I have is:
(COMMAND "SHELL" "net config server /autodisconnect:-1")
I think the spaces and forward slash (and maybe the 🙂 are causing issues.
Any insight is appreciated.  Thanks in advance for your help.
-JP
Message 14 of 14
Just an update...
I think the issue might be that in order to issue this command successfully manually, I need to run CDM "as Administrator".
Not sure there is a way to do that using SHELL in Lisp, but if there is... do tell!
Thanks again!
”Boost
