Does Autodesk still proved a DWG library for developers?
oransen
Message 1 of 9
oransen
Does Autodesk still proved a DWG library for developers do that other companies can import and export AutoCAD DWG files?
If so does anyone know ho much it costs?
TIA,
Owen
Replies (8)
Message 2 of 9
Sea-Haven
Please explain more what it is your trying to do. Is it make a dwg without CAD there is a package out there.
Message 3 of 9
oransen
Yes, I should have said "Sell" or "provide" not "prove". Old neurons!
A company has asked me to find out if they can buy a library (C++) (from Autodesk) which will read and write DWG files. They do not make CAD programs, but their clients use AutoCAD.
Message 4 of 9
daniel_cadext
realdwg?
https://aps.autodesk.com/developer/overview/realdwg
I don't know about the cost
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
Message 5 of 9
Sea-Haven
Message 6 of 9
oransen
Many thanks.
Message 7 of 9
hak_vz
If their clients use AutoCAD then they don't need RealDWG licensing. To interact with AutoCAD they can create programs inside it or around it using autolisp/visual lisp, dotNet (c++, C#, F# and visual basic), Python and JavaScript. Reading writing to dwg/dxf are carried out by AutoCAD . If they want to use RealDWG in an application that is not related to AutoCAD , but they i/o functionality for this data format, then they need license agreement. Current yearly cost of license for up to 10 000 users is 8000 US$/7500 € as stated here.
Miljenko Hatlak
Message 8 of 9
Sea-Haven
There is another I think its called open alliance, but again a cost.
maybe this Open Design Alliance - Wikipedia
A sort of non cost is write DXF as its a ascii version of a dwg open in notepad etc and have a look, depending on how complex a dwg required may be a simple way out.
Message 9 of 9
oransen
The company already does that, but some of their customers want DWG input and output, and a DXF library needs constant updating. In the end it may cost less to go with RealDWG, though that is a choice they will have to evaluate economically.
Thanks for the suggestion though.
