Does anyone know a tool to detect "Hybrid drawings"?
Message 1 of 9
I have some customers with thousands of DWGs, of which at least a couple of thousand are hybrid drawings, i.e. where you have a DWG with an XREF to a TIFF. I need to identify these in a better/faster way than manually opening and checking. We have written a small Java program that just looks for certain patterns in the DWG files, but this is tricky and only works for a handful of DWG versions. Does anyone know of a tool or script that can scan through a directory structure and identify hybrid files?
Replies (8)
Message 2 of 9
vladimir_michl
DBXscanImg - see https://www.cadstudio.cz/en/apps/dbx/
Vladimir Michl, www.cadforum.cz
Message 3 of 9
Sea-Haven
cadstudio nice options
Using dbx or aeccorconsole and look inside for xrefs the Tiff shoud be listed there, as images normally get stored as a xref.
Check out Lee-mac.com for dbx program source.
Message 4 of 9
Hi!
@vladimir_michl
Thanks for you answer, the DBXscanImg and DBXscanXref tools look good, but it seems like I am getting a lot of false positives in the DBXscanXref. Opening several files in AutoCAD or DWG TrueView shows no External References, although the files are reported by the DBXscanXref tool.
Any suggestions?
Message 5 of 9
vladimir_michl
I think the DBXscanXref reports also those attached xrefs which are currently "unloaded".
Vladimir Michl, www.cadstudio.cz - www.cadforum.cz
Message 6 of 9
Looks like the idea of DBXscanXref is good, but it does not work the way I need. With so many false positives, I have to manually go through thousands of files...
Any other suggestions out there?
Message 7 of 9
john.uhden
Yes.
You send all your DWGs to @dougbroad and he will sort them into a separate folder for you.
He's just that kinda guy.
John F. Uhden
Message 8 of 9
Thanks for the suggestion, but I cannot do that 🙂
Drawings are for a power distributor, and quite a bit of them are classified 🙂
Message 9 of 9
I ended up writing my own little piece of VBA, finding blocks of IAcadModelSpace having items of IAcadRasterImage. Did the trick for me.
