Hi all.
I have a question about how to disable automatic grid addition in the viewport when creating a new viewport. The problem is that if the GRIDMODE system variable is set to 1, then when a new viewport is created using the "_-vports" command, the grid is activated in the created viewport. In this regard, my question: is it possible to disable the addition of a grid, create a reactor so that when the "_-vports" command is run, the GRIDMODE system variable is set to 0, and after the command is executed, the GRIDMODE variable should return to 1? If this is not possible, in this case, is it possible to switch the variable GRIDMODE 0 when switching to Paper Space, and setting GRIDMODE 1 when switching to Model Space? Unfortunately I do not know how to create reactors, so I am asking this question here.
